Speedo drive query - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Speedo drive query (/showthread.php?tid=71955) |
Speedo drive query - Tommyk - 25-03-15 Hello foccers could anyone be kind enough to explain the relationship between the speedo drive, the clocks and the tps I'm doing a usd conversion and would like to know the effect of removing/changing the speedo drive to suit the new front wheel I know it causes problems but I don't know what or why any advice would be great Thanks in advance Re: Speedo drive query - rhinoeli - 26-03-15 Bike runs well without speedo sensor. The only drawback is obvious, speedo shows 0 all the time. The original sensor on the front wheel's left side works with 5 Volts, gives 4 pulses per rotation. The new setup should do the same (assuming same wheel circumference) if you want proper speedo readings. Re: Speedo drive query - kebab19 - 26-03-15 Look at Muddybuddy's original post on using the FZ1 speed sensor (or my own more recent R6 front fork conversion thread) to see how to bypass this issue whilst using alternative front-ends PM me if you need more in-depth details Re: Speedo drive query - risticuss - 26-03-15 Kebab, have you got a link for those threads as I've searched and searched and only found hints of them, with no definitive pointers on how it was done. I know you don't want to give away all your secrets and knowledge, but a push in the right direction would be nice
Re: Speedo drive query - darrsi - 26-03-15 Is this it? http://foc-u.co.uk/index.php/topic,14254.msg162228.html#msg162228 Re: Speedo drive query - Punkstig - 26-03-15 (26-03-15, 07:10 AM)rhinoeli link Wrote: Bike runs well without speedo sensor. The only drawback is obvious, speedo shows 0 all the time. And the Rev counter showing a fault code once it's taken over 10k If you have/ or get hold of the plastic version of the sensor then you may be able to file and shape it to fit the new wheel like I did- no removal of sensor = no problems! Re: Speedo drive query - Tommyk - 26-03-15 Thanks guys still a little confused Bit more research required Re: Speedo drive query - kebab19 - 26-03-15 Darrsi: That's the right thread. Risticuss: I haven't intentionally hidden how to do any of this stuff - it's just that no-one seemed to be interested in fitting alternative front-ends on their bike, so I never elaborated any further on my R6 fork thread. To replace the standard speedo sensor unit, use one from either an FZ-1 or FZS1000. Actually there are other Yamahas the same but to date they're the only ones I'm aware of that work. You do however need to extend the wires so they're the same length as the ones on the standard unit (if you want to place it on the front wheel). Tommy: Not sure if I can explain this well but will have a go...I'm sure someone else can finish it off for me (possibly Muddybuddy). Inside the standard speedo unit (at the front wheel spindle area) is that sh1tty wee two-pronged hollow metal unit that breaks on a regular basis every other time you change the front tyre :lol The two prongs where they fit into the front wheel slot are the BIG clue to all this. Those two prongs moving along with the wheel send signals to the clocks etc where speedo information can be estimated. The replacement speedo sensors named above do something similar, but usually operate via the front sprocket on their parent bikes. Both Muddybuddy and myself raised the height of two brake disc bolts a couple of millimetres by inserting small steel washers underneath them. As it's a six-bolt disc bolt pattern for the likes of an R1 / Fazer 1000 front wheel, it worked out very handy, because using two of the bolts facing 180 degrees away from each other effectively emulated the effect of the two sensor prongs. So, if you place the replacement speed sensor the correct height over the disc bolt area (lots of fiddling), only two of the six metal disc bolts will 'activate' the speed sensor. This will then send an accurate reading to the original speedo clocks / TPS blah blah blah. And of course allow you to fit any front-end you like to the Fazer Look closely at the 3rd picture down on my R6 fork thread: http://foc-u.co.uk/index.php/topic,15854.msg181989.html#msg181989 You should see the revised speedo sensor bolted in place via the lower caliper mounting hole and 'hanging' over the brake disc bolts. You should also see the two raised disc bolts at about 11 0'clock and 5 o'clock if the brake disc were a clock face. It's these two bolts rotating past the FZ1 speed sensor that activates the signal sent to the clocks etc and emulates the original speed sensor effect. Re: Speedo drive query - Tommyk - 27-03-15 That has made it perfectly clear kebab Thanks a lot for taking the time to explain I've had me stem swap done and spacers made I have r1 front wheel and discs , fender So speed sensor was unsure about but that's cleared it up for me Got a week off work so wanna try and get it all done starting with a service tomorrow just to make sure she running perfect My fazer is naked with after market headlight that I've never really liked so wanna do something about that aswell and thinking maybe clipons aswell so gonna be busy Doing my first ever bike mod Slightly nervous that I'm gonna mess my bike up but excited aswell as always wanted to do something like this will probably have an r6 rear shock off you if all goes well Thanks again to all the other lads for the advice watch this space for lots of silly questions over the coming week Re: Speedo drive query - Tommyk - 27-03-15 Ok been on eBay not much to choose from Does the sensor have 3 wires and a triangular plug? Re: Speedo drive query - kebab19 - 28-03-15 Hi Tommy, Yes, the electrical end-plug is the same as the standard FZS600, which is handy :lol Not much to choose from on Ebay? Some fine tuning required on those search skillz 271309437425 151556442496 181370420410 161271117161 351098857168 I think you might want to get in touch with Muddybuddy - he swapped his front-end to a R1 4XV setup, so may be able to advise you in-depth on your own conversion. Also, he ran his speed sensor to the rear wheel, placing the sensor on top of the end of the swingarm, whereas I went with placing it at the front wheel. As long as you are able to space the raised disc bolts correctly and set the sensor the right height to them, it doesn't matter which wheel you opt for. Re: Speedo drive query - risticuss - 28-03-15 Kebab you are a leg-end. That's spot on. I just need to persuade a mate to sell me his R1 front end now. Re: Speedo drive query - Tommyk - 29-03-15 Thanks kebab sensor ordered Got the tank and carbs drained yesterday No wonder it was running so rough might have a tank issue new filters and plugs fitted Running good now so gonna crack on with forks tomorrow cheers again |
