not starting - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: not starting (/showthread.php?tid=71920) |
not starting - mally00 - 22-03-15 hi every one , hope you can help with a problem I my of caused my self . starting to clean the carbs , I was taking the battery off , I tuck the negative terminal then as I was taking the positive terminal off , the negative terminal slid and touched and my spanner touched the frame and sparked . carried on cleaned carbs , now bike will not start put new coils on tested tps tested starter rely put another icu says from working bike the bike backfires though carb Re: not starting - clayt74 - 22-03-15 Gotta be a blown fuse??? Always disconnect neg then pos,!! ! Reconnect pos then neg!! Good luck Re: not starting - sinto607276 - 22-03-15 That's my thought too, check your main fuses, always first choice when you do that sorta thing,. And as already said positive first! I always remember it by saying..."be positive first as you can always be negative later " Re: not starting - clayt74 - 22-03-15 And as already said positive first! I always remember it by saying..."be positive first as you can always be negative later " [/quote] That's a quote to live by!!! Love it
Re: not starting - sinto607276 - 22-03-15 Sure is clayt74, you can use it now as I got very you permission B-) Re: not starting - sinto607276 - 22-03-15 Give you permission I meant lol Re: not starting - mally00 - 23-03-15 thanks every one for your advice / problem solved have a laugh put the wrong wires to the wrong coils so them tonight changed round fired first go Re: not starting - sinto607276 - 24-03-15 Glad you've got it sorted now, happy riding ;-) |
