k&n filter vibe issue - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: k&n filter vibe issue (/showthread.php?tid=71919) |
k&n filter vibe issue - scoobie_paws - 22-03-15 Ok so i changed out the air filter from standard to k&n And it has made the bike really vibey. Always has the 6k buzz but now get vibes all thru the range. Any ideas why? Wondered if it had made mixtures too lean but no idea if that would cause the vibes? Def increased acceleration so would like to keep it but making it uncomfortable to ride. Any thoughts? Re: k&n filter vibe issue - rhinoeli - 22-03-15 Did you have the carbs synced after the change? Re: k&n filter vibe issue - scoobie_paws - 22-03-15 (22-03-15, 08:47 AM)rhinoeli link Wrote: Did you have the carbs synced after the change? nope just wacked it in might be worth a look. always had bad buzz at 6k but rode around it Re: k&n filter vibe issue - Davew - 24-03-15 that's interesting, as I have always had annoying vibe issues that I've mostly sorted. Might check my airbox isn't causing vibes by padding the filter out slightly where it rests on the bottom of the box or something. Re: k&n filter vibe issue - darrsi - 24-03-15 (24-03-15, 12:42 PM)Davew link Wrote: that's interesting, as I have always had annoying vibe issues that I've mostly sorted. Might check my airbox isn't causing vibes by padding the filter out slightly where it rests on the bottom of the box or something. Does it rest on the bottom? Re: k&n filter vibe issue - Davew - 24-03-15 I mean the filter inside the box, not the box itself, sorry. I wonder if the filter isn't a snug fit and is vibrating slightly. I remember tightening the airbox up when I bought the bike which helped the vibes a little. Re: k&n filter vibe issue - darrsi - 24-03-15 (24-03-15, 01:20 PM)Davew link Wrote: I mean the filter inside the box, not the box itself, sorry. I wonder if the filter isn't a snug fit and is vibrating slightly. I remember tightening the airbox up when I bought the bike which helped the vibes a little. I meant the filter too, don't actually know if it touches the bottom of the air box, but a K&N is very snug and well fitting around the top so won't vibrate there. Cheaper air filters can be ill fitting and loose in comparison. Re: k&n filter vibe issue - Davew - 24-03-15 OK, will have a look and see. could well be vibrating from the top if it is loose I guess. Re: k&n filter vibe issue - darrsi - 24-03-15 My old air filter I had for about a week which was crap had about 5mm of play around the top, but I never knew it was ill fitting until I put the K&N in, which fits absolutely perfectly. |
