FZ1 sub-throttle MODt - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: FZ1 sub-throttle MODt (/showthread.php?tid=71859) |
FZ1 sub-throttle MODt - CharlieDee - 15-03-15 evening Foccers, Has anyone done the sub-throttle MOD? If so what did you no Re: FZ1 sub-throttle MODt - CharlieDee - 15-03-15 Sorry... The iPad did its own thing there... What did you notice after the MOD? Does anyone know where they can be purchased? Cheers mokin
Re: FZ1 sub-throttle MODt - slappy - 15-03-15 Do you mean trimming the secondary butterflies? If so there a few vids on youtube that show how it is done, still thinking about doing it to mine but unsure whether it is worth it. Re: FZ1 sub-throttle MODt - devilsyam - 16-03-15 Ivan or copperdawg both cheap more mid range better spread no good unless done with other mods Re: FZ1 sub-throttle MODt - CharlieDee - 16-03-15 Cheers guys... I intend doing all the necessary upgrades at the same time... :lol Re: FZ1 sub-throttle MODt - Fazafou - 16-03-15 I put on a Fuel silencer and took the flies out completely (rather than trimming). The effect is marginal to be honest and I've even thought about putting them back as the mid range is a little down. Top end is great on the other hand and it screams away no problem once past about 5k. If you're doing air filter or something it's worth a play with, but effect isn't enough to bother with the grief if you're not doing anything else IMO. Re: FZ1 sub-throttle MODt - DekF - 16-03-15 Removing the secondary flies gives a significant boost to throttle response & torque. I tried all the permutations. Ziptied, smaller, none & no flies & spindle. The best throttle response was with no flies & removed spindle. The mod requires a significant amount of fuel added at part & mid throttle openings. We did umpteen dyno runs in 06/07 to get it right. It will not work without a pc3,V or bazzaz etc. Anyone who says it isn't worth it is running the wrong fuelling map. Re: FZ1 sub-throttle MODt - Fazafou - 17-03-15 (16-03-15, 11:14 PM)DekF link Wrote: Anyone who says it isn't worth it is running the wrong fuelling map. Or running stock if that wasn't clear from my post. |
