Problems starting - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Problems starting (/showthread.php?tid=71828) |
Problems starting - Jrebera - 12-03-15 so my throttle cable snapped after stopping to fuel up. I managed to dismantle the housing, yank the cable and ride Home. However, in messing around with it before getting it started it backfired. Got it home, got a new cable and changed it (wasn't as easy as I thought it would be). Anyway, now it is a bitch to start. I ,mean, a real bitch. It is getting worse too. It backfires too - and then starts on the backfire. If I shut off the fuel, it sometimes starts, then I switch it on again. Once started it is a dream. Just getting the thing started. Anyone advice? Re: Problems starting - Fazerider - 12-03-15 The fact that it runs well once started makes me think the sparks are ok. It may be running rich on one (or more) carbs, if one's flooding a bit that would explain the backfiring and why turning the fuel off helps. Try checking the fuel levels in the carbs. Re: Problems starting - unfazed - 12-03-15 Drain the float bowls and see if that solves it, might have a float stuck |
