Engine Fault Light Help - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Engine Fault Light Help (/showthread.php?tid=71740) |
Engine Fault Light Help - Grayo - 05-03-15 I've just had the yellow engine fault light come on and the handbook says it's an electrical fault. (2008 FZ1) Is this a common problem ? If so, does anyone know where I should be looking or does it need to go to the dealer to be sorted. Thanks in advance. Re: Engine Fault Light Help - slappy - 05-03-15 Do you get an error code as well? Re: Engine Fault Light Help - Grayo - 05-03-15 No error code. I've had the battery on charge for an hour so and now the light has gone out. Would a battery problem cause the light to come on ? Re: Engine Fault Light Help - slappy - 05-03-15 A low battery could have caused it, not totally sure about this but I think the ecu senses the low voltage and turns off non essential stuff, this then causes the engine light to come on. I have also heard it can happen from a loose connection, if you keep the battery charged up and it happens again check all the connections for tightness/corrosion. Re: Engine Fault Light Help - Grayo - 05-03-15 (05-03-15, 08:19 PM)slappy link Wrote: A low battery could have caused it, not totally sure about this but I think the ecu senses the low voltage and turns off non essential stuff, this then causes the engine light to come on. Ok, thanks for that. Re: Engine Fault Light Help - noggythenog - 05-03-15 Check this out Grayo, an old post regarding how to use the diagnostics tool and find the codes. http://foc-u.co.uk/index.php/topic,5766.msg50597.html#msg50597 I had the light come on once, i was gutted but i took it out for a spin and it was fine....next day i go out to ot and the light no longer came on....but i have an intermittent starting issue which i still need to rectify (been sayi g it for about 4 months now :rolleyes ) which is most likely a dodgy connector somewhere......i have just got some contact cleaner and dielectric grease so i can go through as many connectors as i can get to......fingers crossed it'll sort my issue. [size=78%]Ive never done contacts before so not sure what to expect but if any of the connectors look particularly corroded then ill post up which ones coz the way i see it, could be inherrent and other bikes with simillar age/mileage could suffer the same. [/size] Re: Engine Fault Light Help - Grayo - 05-03-15 That's great, thanks Noggy. I turned the ignition on about an hour ago and the light was off. Think I'll order a new battery first and take it from there. Re: Engine Fault Light Help - Grayo - 07-03-15 I'm now sure it's a battery fault. If I turn the ignition on when the battery is on charge the engine fault light is out. As soon as I unplug the charger and turn the ignition on, the engine fault light comes on. New Motobatt battery has been ordered. Re: Engine Fault Light Help - Grayo - 11-03-15 Just fitted the new battery and all is well again. No engine fault light.
