Spraying fz1 frame. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Spraying fz1 frame. (/showthread.php?tid=71704) |
Spraying fz1 frame. - brooker81 - 02-03-15 Need to do a bit of touching up on fz1 frame where the rear hugger has vibrated the paint off. I was wondering if Simonez satin Matt Black is a decent match (devilsyam says it is) Has anyone tried sparaying it i was wondering if the paint takes ok or should look at other options for sorting it out? Re: Spraying fz1 frame. - Grayo - 02-03-15 I bought some paint from RS Paints and sprayed my frame and swinging arm (2008 FZ1) and then lacquered them. Paint was a perfect match. I rubbed it down gently first with some 1200 grit wet and dry and it turned out perfect. Paint was Cob Yamaha 20918 Power Black and Matt Lacquer. Re: Spraying fz1 frame. - bigbluebear - 02-03-15 Depends on how bad it is, I would try a small area first and dab it with a very small paint brush, let it dry and see how it blends in. Re: Spraying fz1 frame. - brooker81 - 02-03-15 Its not too bad just me being a prick really. Easy fix is forget carbon hugger and put original back on lol. Where do u get rs paints from? Re: Spraying fz1 frame. - Grayo - 02-03-15 (02-03-15, 10:27 AM)brooker81 link Wrote: Its not too bad just me being a prick really. Easy fix is forget carbon hugger and put original back on lol. Where do u get rs paints from? Either from their website www.rsbikepaint.com or give them a ring 01707 273219. Re: Spraying fz1 frame. - pilninggas - 02-03-15 i did a couple of 'rubbing-spots'; i used etch primer on an artists brush and then a matt black spray paint I had hanging around (I spray a little into the cap and then load the brush lightly) Re: Spraying fz1 frame. - brooker81 - 03-03-15 Quote:i did a couple of 'rubbing-spots'; i used etch primer on an artists brush and then a matt black spray paint I had hanging around (I spray a little into the cap and then load the brush lightly) how where your results? |
