Brakes...Help! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Brakes...Help! (/showthread.php?tid=71674) |
Brakes...Help! - Rikki - 27-02-15 Hi folks I've just been cleaning my calipers, put rubber grease on the pistons etc. When I was pushing them back in, one of them popped out - not completely but enough for a few drips of fluid to leak out. What consequences might this have? Not sure if any air got in the caliper or not. Any advice? Re: Brakes...Help! - darrsi - 27-02-15 When you say popped out, did it go past the seal? Re: Brakes...Help! - Paulfzs - 27-02-15 bleed the brakes dont risk it ! 20 minutes of messing around is better than weeks of being deaded because your brakes stopped working and you hit a roaming cow Re: Brakes...Help! - darrsi - 27-02-15 (27-02-15, 03:35 PM)Paulfzs link Wrote: bleed the brakes dont risk it ! Pesky Roman cows. Re: Brakes...Help! - Rikki - 27-02-15 Think it must have edged past the seal (or at least part of it - was at a slight angle when it happened) in order for the bit of fluid to leak out. It slipped straight back in though & was only out of place for a fraction of a second. Would bleeding remove any potential bubbles in the caliper? I think I read about a technique on here where you remove the master cylinder cover, tie the brake lever back & leave it for a few hours for bubbles to migrate to the top of the system. Or it could have been a dream, I'm not 100% sure. Anyone else heard of this? Re: Brakes...Help! - Paulfzs - 27-02-15 (27-02-15, 03:44 PM)darrsi link Wrote: [quote author=Paulfzs link=topic=16096.msg185046#msg185046 date=1425047738] Pesky Roman cows. [/quote] :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin Re: Brakes...Help! - HarryHornby - 27-02-15 If it's the rear caliper on a 600 I wouldn't bother, they're shite and ain't gonna stop you hitting a cow from any culture, bled or unbled! :b (Says he who's going to be giving his 600 rear caliper some maintenance love this weekend) Re: Brakes...Help! - darrsi - 27-02-15 (27-02-15, 04:18 PM)Rikki link Wrote: Think it must have edged past the seal (or at least part of it - was at a slight angle when it happened) in order for the bit of fluid to leak out. It slipped straight back in though & was only out of place for a fraction of a second. Yep you heard right, I normally do that trick after my brakes have been bled, it tends to sharpen them up that little bit more, so definitely worth a go. Best to leave it over night though. If you loosen the MC lid make sure the bike won't get touched and I normally stick loads of rag around it in case of any accidental spillage. I've been known to leave something on my seat to remind me as well, I'm not a morning person! Re: Brakes...Help! - Jules-C - 27-02-15 If the brake feels normal and not spongy you haven't let enough air in to be a problem. But bleeding it won't do any harm either way. Re: Brakes...Help! - Rikki - 27-02-15 (27-02-15, 05:17 PM)HarryHornby link Wrote: If it's the rear caliper on a 600 I wouldn't bother, they're shite and ain't gonna stop you hitting a cow from any culture, bled or unbled! :b (Says he who's going to be giving his 600 rear caliper some maintenance love this weekend) I hear what you say about the rear caliper. Just spent a couple of hours on that one alone. Pushed the pistons out & cleaned them. Would they go back in? Hell no. Used a G-clamp to apply pressure. Broke the G-clamp! Used a bigger G-clamp. Faffed about for a l-o-n-g time & finally got them in far enough to get it back on again. Haven't been for a test ride yet - will do this over the weekend & report back with the results. Right now though it's time for the pub! Cheers all! Re: Brakes...Help! - darrsi - 27-02-15 (27-02-15, 07:22 PM)Rikki link Wrote: [quote author=HarryHornby link=topic=16096.msg185060#msg185060 date=1425053860] I hear what you say about the rear caliper. Just spent a couple of hours on that one alone. Pushed the pistons out & cleaned them. Would they go back in? Hell no. Used a G-clamp to apply pressure. Broke the G-clamp! Used a bigger G-clamp. Faffed about for a l-o-n-g time & finally got them in far enough to get it back on again. Haven't been for a test ride yet - will do this over the weekend & report back with the results. Right now though it's time for the pub! Cheers all! [/quote] Shouldn't be that tough to push back in at all. Re: Brakes...Help! - Paulfzs - 27-02-15 my original rear took tones of pressure to get back in, my fzs thou caliper i can do with my fingers |
