Help..........Damper rod removal - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Help..........Damper rod removal (/showthread.php?tid=71622) |
Help..........Damper rod removal - Rexr - 21-02-15 Just stripping down my gen 1 1000 forks to put in new seals and have a wee problem I can't get the damper rod out any suggestions on this would be appreciated Re: Help..........Damper rod removal - fazed out - 21-02-15 (21-02-15, 06:32 PM)Rexr link Wrote:Just stripping down my gen 1 1000 forks to put in new seals and have a wee problem I can't get the damper rod out any suggestions on this would be appreciatedtape a 27mm socket to a piece of tube then slide it down inside of forks after you taken spring out use a allen key at the bottom of forks then you can undo they arn't very tight Re: Help..........Damper rod removal - Rexr - 21-02-15 (21-02-15, 07:15 PM)fazed out link Wrote:[quote author=Rexr link=topic=16044.msg184321#msg184321 date=1424539951]tape a 27mm socket to a piece of tube then slide it down inside of forks after you taken spring out use a allen key at the bottom of forks then you can undo they arn't very tight [/quote] Cheers will give that a go in the morning.... Re: Help..........Damper rod removal - Rexr - 22-02-15 Cheers for that Fazed-out......all sorted now...... |
