clutch lever pivot - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: clutch lever pivot (/showthread.php?tid=71587) |
clutch lever pivot - Tuckerhauser - 17-02-15 Evening had my gen 1 Fazer since Sept and the clutch lever has always had a wobble! I bought the bike of a mate who fitted aftermarket levers but I know the standard levers that were fitted when he bought it wobbled too After looking at microfiche there's a spacer in the pivot but the hole thru the spacer is bigger on my bike than the diameter of the bolt that secures lever. Can anyone confirm that the bolt/spacer is correct? Before I start buying parts;-) Thanks ![]()
Re: clutch lever pivot - slappy - 17-02-15 I can't confirm whether that is the correct spacer or not but sometimes the bolt or spacer can get worn and cause the lever to feel wobbly. That happened on my old ZRX1100, only cure was new spacer bush and bolt. Re: clutch lever pivot - stevierst - 17-02-15 I think most of my bike brake levers have wobbled! One thing I have noticed is that after market lever bushes are generally a crap fit and have a lot of play in them. I've had to make my own bushes to reduce the wobble. The flip side is if they're too tight, they bind with the housing, create a stiff lever action, and wear the lever mountings prematurely. Re: clutch lever pivot - Tuckerhauser - 18-02-15 Thanks for the replies Think ill order a new spacer see if that helps Re: clutch lever pivot - nickpeh - 24-02-15 It could be your lever mounting hole elongated, bushing material is harder than the lever. U try to put in the bushing to the lever mount hole see if there's excessive movement when u rotate it, if it is...change the lever to get a more accurate feel. Re: clutch lever pivot - Tuckerhauser - 24-02-15 Mate made a new bush for me on his lathe Fitted it last nite, its alot better takes the excessive wobble out of lever |
