Steering Head Bearings - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Steering Head Bearings (/showthread.php?tid=71515) |
Steering Head Bearings - bigbluebear - 10-02-15 Does anyone know when the steering head bearings should be changed.....I've done 30k on my mighty 2004 thou and not sure if there is a limit on these things.......thinking about changing them while other work is being carried out. Re: Steering Head Bearings - nickodemon - 10-02-15 They only need replaced if worn. If the bike is being taken apart anyway i would repack the bearings with grease. You can visually check them for wear. Look at the rollers and check the surface for wear marks. Usually the polished surface of the bearings looks darker (The outer shell coating is wearing away)
Re: Steering Head Bearings - bigbluebear - 11-02-15 Cheers Nick.....just ordered new ones to keep the mighty Fazer Thou in tip top condition. Re: Steering Head Bearings - nickodemon - 11-02-15 Did you buy original bearings(ball bearings in a cage) or taper roller bearings? If you ordered tapers you will need to drift out the old races in the headstock and fit the ones supplied with the new taper bearings
Re: Steering Head Bearings - bigbluebear - 11-02-15 (11-02-15, 01:44 PM)nickodemon link Wrote: Did you buy original bearings(ball bearings in a cage) or taper roller bearings? If you ordered tapers you will need to drift out the old races in the headstock and fit the ones supplied with the new taper bearings originals Re: Steering Head Bearings - nickodemon - 11-02-15 That will be a nice easy swap
