Fork Seal replacement - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Fork Seal replacement (/showthread.php?tid=71503) |
Fork Seal replacement - Jamieg285 - 08-02-15 One of the fork seals has started leaking and I'm going to replace it. I've read the guide and plenty of other posts on the subject, so know what's entailed. What I am not so sure about is whether I need to replace the bushing too. Budget is tight, so I don't want to spend out if I don't have to. If the bushings are worn, what's the downside of not replacing them? Bike has done just over 60K and I don't know if/when any of the fork internals were serviced. The dust caps do look a bit chewed, as if they have been removed/lifted and re-used. Re: Fork Seal replacement - Chris - 09-02-15 Chances are they are probably ok. However if you can afford to buy them then it would really be worth replacing them while the forks are apart. Chris Re: Fork Seal replacement - Arfa - 09-02-15 A job that's next on my list. I'm no expert though, so canna answer your questions too well! Also being on a budget, but still wanting to stick to genuine seals, found cheapest here: Motorcyclespareparts.eu, especially now the Euro has really dropped against the pound. Check the clips around the seals too, mine have corroded a bit which isn't going to help matters. They're only a couple of quid anyway. Re: Fork Seal replacement - His Dudeness - 09-02-15 If they're heavily worn they can cause the seal to leak. You're not going to know what condition they're in until you take them apart. Re: Fork Seal replacement - Jamieg285 - 09-02-15 (09-02-15, 09:56 AM)Arfa link Wrote: Also being on a budget, but still wanting to stick to genuine seals, found cheapest here: Motorcyclespareparts.eu, especially now the Euro has really dropped against the pound. Check the clips around the seals too, mine have corroded a bit which isn't going to help matters. They're only a couple of quid anyway. I found Fowlers were cheapest... Re: Fork Seal replacement - Triggergee - 14-02-15 Fowlers?! In Bristol? I find them as dear as anywhere which is a shame as its five mins away Re: Fork Seal replacement - Skippernick - 14-02-15 If you replace the fork oil do you need to replace the seals as well? Re: Fork Seal replacement - Gnasher - 14-02-15 No
Re: Fork Seal replacement - Skippernick - 15-02-15 (14-02-15, 07:04 PM)Gnasher link Wrote: No Thank you. |
