Air filters compatible? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Air filters compatible? (/showthread.php?tid=71500) |
Air filters compatible? - The Gentleman Biker - 08-02-15 Evening chaps, I'm pretty sure the FZS600 air filter is exactly the same as the 400 model? Thought I better check before ordering a K&N. Also are all the FZS600 models the same filter? Re: Air filters compatible? - His Dudeness - 09-02-15 The 600 uses the 400 air filter. If you have a look at the 600 parts manual. Anything with 4YR at the start of the part number comes from the 400 bike http://foc-u.co.uk/index.php?PHPSESSID=2fab74b943bece4cca0154363c785def&action=downloads;sa=view;down=13 Re: Air filters compatible? - The Gentleman Biker - 09-02-15 That's fantastic, thank you. Re: Air filters compatible? - His Dudeness - 09-02-15 No problem
