(me again!) What is this called and where do I get one?? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: (me again!) What is this called and where do I get one?? (/showthread.php?tid=71497) |
(me again!) What is this called and where do I get one?? - HJFazer - 08-02-15 Hi, So I feel like maybe my bike is falling apart, given how I seem to be on here with issues quite a lot! However, I do have a new issue and am hoping someone can help out. So yesterday I noticed my front brake wasn't activating the light. Having looked I could see that one of the wires had come loose from the connector of the Front Light Break switch. It should be an easy fix however annoyingly I can't get the wire to stay back in the connector and have currently fixed it using masking tape and hopeĀ :rolleyes This is a photo of the connector I'm trying to replace, I wondered if anyone had any ideas what they were called/where I could get one? http://screencast.com/t/ouUeHfrVre In case my description is terrible, this is what it connects to: http://screencast.com/t/wVj86DINdWB I really can't figure out what it's called in order to try and get a replacement, the current one is set so tight I don't think i can undo it and I'm not sure how long the Tape will hold so any help would be epic! Thanks again HJFazer Re: (me again!) What is this called and where do I get one?? - Gnasher - 08-02-15 Pop along to your local motorfactors or halfords and take the connector with you it's called a right angle spade connector. Re: (me again!) What is this called and where do I get one?? - HJFazer - 08-02-15 Thanks Gnasher! Much appreciated! Re: (me again!) What is this called and where do I get one?? - bigsteve - 08-02-15 If you have no luck in stores these may help but check size and order http://www.ebay.co.uk/itm/25-x-BLUE-6-3mm-Fully-Insulated-FLAG-Terminals-/290468287121?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item43a1425291 Re: (me again!) What is this called and where do I get one?? - Paulfzs - 08-02-15 the same thing happened to mine last week i just used a straight spade connector that i got off ebay. works fine. |
