FZS1000 Clocks - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: FZS1000 Clocks (/showthread.php?tid=71451) |
FZS1000 Clocks - bigbluebear - 02-02-15 I am looking at buying a set of speedo clocks to replace my existing ones....my old clocks are measured in KPH and have been fitted with some kind of modification gizmo to return them back into MPH.....Focced knows where and what this modification actually is but keen to get back to standard MPH clocks. Does anyone know if these can be fitted as a direct replacement without the existing or any modifications etc Re: FZS1000 Clocks - nickodemon - 02-02-15 You will have a speedo convertor fitted. http://www.ebay.co.uk/itm/Speedo-Conversions-KMH-to-MPH-/111373393344?pt=UK_Motorcycle_Parts_13&hash=item19ee5f1dc0 It fits to the end of your speedo cable and into the back of the clocks. If you want to change the clocks to mph ones, you simply take the old clocks off and unscrew the speedo convertor. Refit the speedo cable to the mph clocks. Simples
Re: FZS1000 Clocks - Tmation - 02-02-15 I thought we have an electronic speedo, as in no cable. Re: FZS1000 Clocks - bigbluebear - 02-02-15 (02-02-15, 05:52 PM)nickodemon link Wrote: You will have a speedo convertor fitted. Cheers Nick Re: FZS1000 Clocks - nickodemon - 02-02-15 (02-02-15, 06:04 PM)Tmation link Wrote: I thought we have an electronic speedo, as in no cable.You might be right, as i cant recall. Too many bikes in the garage! If it is an electronic speedo it will have one of these plugged inĀ -http://www.ebay.co.uk/itm/Speedo-speedometer-converter-chip-E-SVA-IVA-KMH-to-MPH-CARTEK-CK-UN-09-/380258508684?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item58892c5f8c Same principle applies. Un plug and change clocks
Re: FZS1000 Clocks - unfazed - 03-02-15 Remove the seat and remove the right side panel (the one under the seat). The speedo sensor lead is located under this panel, most likely there is a speedo healer plugged into the loom somewhere around there. Re: FZS1000 Clocks - keithfzs1000 - 03-02-15 i am replacing my mph clocks soon to aftermarket ones if you need to source some. Approx 30000 on clock no issues with them at allwill be flea baying them for around 100, fellow foccer 90 posted to your door. Re: FZS1000 Clocks - bigbluebear - 03-02-15 (03-02-15, 09:15 AM)keithfzs1000 link Wrote: Thanks, which after market ones are you going for Re: FZS1000 Clocks - keithfzs1000 - 03-02-15 http://www.ebay.co.uk/itm/LCD-Digital-Speedo-Handle-Bar-Risers-In-One-Streetfighter-Dash-Tacho-Gsxr-/111450105028?pt=UK_Motorcycle_Parts_13&hash=item19f2f1a4c4 but needs a billet yoke as they dont fit the R1 due to mounting measurements of risers got the speedo just waiting for yoke to be manufactured Re: FZS1000 Clocks - bigbluebear - 16-02-15 (03-02-15, 01:46 AM)unfazed link Wrote: Remove the seat and remove the right side panel (the one under the seat). The speedo sensor lead is located under this panel, most likely there is a speedo healer plugged into the loom somewhere around there. Cheers...that's exactly where it was....now fitted with a new mph clocks Re: FZS1000 Clocks - JoeRock - 16-02-15 Still got the speedo healer fella? Re: FZS1000 Clocks - bigbluebear - 16-02-15 (16-02-15, 08:12 PM)JoeRock link Wrote: Still got the speedo healer fella? Yes selling the kph clocks too |
