Fitting aftermarket exhaust. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Fitting aftermarket exhaust. (/showthread.php?tid=71310) |
Fitting aftermarket exhaust. - digger - 15-01-15 Hi, Ive just purchased a Fazer 600 2002 and want to fit an after market exhaust. The bike has already got stainless down pipes with a standard can. Can anyone tell me if there is likely to be a metal gasket where the link pipe of the new can join the down pipes? I hope that makes sense. many thanks. Re: Fitting aftermarket exhaust. - BBROWN1664 - 15-01-15 inside the original can, if its not been off too often, you may find a fibre type gasket that goes around the downpipes as they go into the can. Often ends up getting lost and the aftermarket cans don't always need them. If they do, they should come with one. Re: Fitting aftermarket exhaust. - HarryHornby - 15-01-15 Welcome to the forum, and congrats on buying a :faz I hope you got one of the fast red ones...... What can are you thinking of getting? Re: Fitting aftermarket exhaust. - digger - 16-01-15 Cheers chaps. No Harry I've got yellow and black peril. Re: Fitting aftermarket exhaust. - Punkstig - 16-01-15 Most aftermarket end cans and their link pipes are so tight fitting they don't need gaskets, it will be obvious when you come to fit it! Re: Fitting aftermarket exhaust. - Chappers - 18-01-15 i doubt you'll need one, i didn't! i used some instant gasket paste though just to make sure! |
