Errant cable tie/clip - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Errant cable tie/clip (/showthread.php?tid=71275) |
Errant cable tie/clip - YamFazFan - 09-01-15 Found this on the cylinder head,wedged by a spark plug.Any idea where it has dropped from/goes back to? Thanks guys.YFF. Re: Errant cable tie/clip - His Dudeness - 09-01-15 That's a female fertility symbol. You can be expecting a new baby by the third moon :lol Re: Errant cable tie/clip - Exupnut - 09-01-15 That looks like it's from a coil.... The wife's :-) Re: Errant cable tie/clip - darrsi - 09-01-15 It's doesn't look too important, as you say, just a cable tie. Re: Errant cable tie/clip - risticuss - 10-01-15 I think it's off the clutch cable or there abouts on the left hand side of the tank, just holds a couple of electrical cables together. I wouldn't worry too much. Re: Errant cable tie/clip - unfazed - 10-01-15 It probably the one that hold the fuel pipe on to the under side of cross rail on the frame under the tank. It fits around the cross rail between the wiring harness and the green fuel sender connector Re: Errant cable tie/clip - YamFazFan - 10-01-15 (10-01-15, 09:02 PM)unfazed link Wrote: It probably the one that hold the fuel pipe on to the under side of cross rail on the frame under the tank. It fits around the cross rail between the wiring harness and the green fuel sender connector Ta for info mate.That sounds very likely the one.Especially considering where it has landed.Will have a gander tomorrow.I think it may have been dropped when the tank was last off to change the air filter.The clutch/choke/switch wiring one is still in situ. |
