removing generator cover fazer 1000 gen 1 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: removing generator cover fazer 1000 gen 1 (/showthread.php?tid=71273) |
removing generator cover fazer 1000 gen 1 - nickodemon - 09-01-15 If i remove the generator cover, how much oil will come out? Is it the amount that's behind the casing or will it keep flowing out until the engine oil runs out completely. The reason i'm asking is should i change the oil when removing it or will i get away with just losing a small amount.. The other thing is will i need to replace the gasket or do they usually come off with a tap on the casing and gentle removal. Re: removing generator cover fazer 1000 gen 1 - Grayo - 09-01-15 You shouldn't get any oil from the generator cover but yes, you will need a new gasket. Re: removing generator cover fazer 1000 gen 1 - nickodemon - 09-01-15 I always thought there was at least a small amount of oil? I know different bikes do different things, so thought i better ask the question
Re: removing generator cover fazer 1000 gen 1 - devilsyam - 10-01-15 On the center stand you will loose a bit not much trick is to put 1/2 bit wood or summat to give slight tilt not to much as fucked will fall over this way loose no oil Re: removing generator cover fazer 1000 gen 1 - nickodemon - 10-01-15 Cheers :thumbup |
