Fsz600 2003 smoking a bit - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Fsz600 2003 smoking a bit (/showthread.php?tid=71226) |
Fsz600 2003 smoking a bit - Kentish - 04-01-15 I notice it more when I look in my mirror and have a car behind me because it's light are shining on the back of the bike. It's worse when stationary. I notice other bikes the smokes tends to clear when they warm up but my fazer doesn't seem to do that. I Noticed this a lot of it rains or its cold? Should I be checking something? Re: Fsz600 2003 smoking a bit - unfazed - 04-01-15 That would be normal on a cold or wet day until it the engine heats up. Is it blue or white smoke? Re: Fsz600 2003 smoking a bit - Dave48 - 05-01-15 You need to check this on a mild/dry day. For every gallon of fuel your engine burns it will produce a gallon of water vapour as a product of combustion which is much more evident on a cold damp day. If your engine is in good condition this isnt a problem but white SMOKE as opposed to vapour on a normal warm day indicates a problem. Re: Fsz600 2003 smoking a bit - darrsi - 05-01-15 My money's on it just being the cold weather, it takes a bit of getting used to, but I doubt you'll have a problem. Depending how long you've had it sitting around for, and also if you do any short journeys, then you may even have a nice blob of mayonnaise on the underside of your oil cap as well, which is an eye opener as well until you read up on it, it's normal. Re: Fsz600 2003 smoking a bit - BBROWN1664 - 05-01-15 put your hand (or a tissue) over the exhaust outlet when it's idling. You should just get a wet (and warm) hand. You may get a slight bit of oil mist coming through too but not too much. If your hand turns black from oil you have a problem. Re: Fsz600 2003 smoking a bit - gerkin - 05-01-15 are you using any oil? Re: Fsz600 2003 smoking a bit - Kentish - 05-01-15 (05-01-15, 09:50 PM)gerkin link Wrote: are you using any oil? No I don't seem to be. Thanks for the replies people much appreciated as usual. I shall check it when the weather gets a bit warmer Re: Fsz600 2003 smoking a bit - fazersharp - 05-01-15 (05-01-15, 06:30 PM)BBROWN1664 link Wrote: put your hand over your exhaust outlet You should just get a wet (and warm) hand.Bad curry maybe last night I know sorry !!! Re: Fsz600 2003 smoking a bit - Deefer666 - 06-01-15 If its not loosing oil or coolant then my money is on water vapour from the damp air. |
