Broken holders on Fairing - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Broken holders on Fairing (/showthread.php?tid=71223) |
Broken holders on Fairing - Bimbam - 04-01-15 Hi I have a broken holder on the fairing. It is the holder for the inside plastic cover on each side of the tank. Is this a standard problem? I have used Epoxy glue and two homemade metal pieces. I hope this will fix it. Bimbam Re: Broken holders on Fairing - Bimbam - 10-01-15 All is fixed and well! The epoxy glue did the job and finished with black paint. But no replys, so i guess i am the only one with this problem. Re: Broken holders on Fairing - limax2 - 10-01-15 Probably not a common problem as it is not under much stress if panel is properly fitted. Good to see you managed to fix it ok. Re: Broken holders on Fairing - ste131 - 13-01-15 I tend to use Q-Bond. Great stuff for cracks and reinforcing plastic. |
