R1 gear linkage mod ? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: R1 gear linkage mod ? (/showthread.php?tid=71185) |
R1 gear linkage mod ? - Woodzey80 - 30-12-14 Anyone know if this looks like an r1 gear linkage arm ? Has anyone on the forum done this mod to a fazer ??? Re: R1 gear linkage mod ? - Falcon 269 - 01-01-15 It could be but if it is, I believe it's from an original '98 model 4XV. If that's right, I don't think it will fit the Fazer in the way you might be hoping. Best option for this mod is a 99 - 00 5JJ model R1 arm but later ones can also be used if you reverse the position of the rose joint. Re: R1 gear linkage mod ? - Woodzey80 - 01-01-15 Cheers, thanks for the advice ! Re: R1 gear linkage mod ? - nickodemon - 01-01-15 I did the mod a few years ago. It basically shortens the travel of the gear lever. It makes it slightly stiffer to change gear because the travel is reduced, but it's a worthwhile mod in my opinion. Ps.. make sure the linkage rod doesn't make contact through the frame. I had to file mine so it didn't touch when changing gear.
