Gear lever confusion - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Gear lever confusion (/showthread.php?tid=71083) |
Gear lever confusion - Jamieg285 - 12-12-14 I hope someone can help me identify what year this gear lever is from. The spring on the footrest broke, so I bought a complete footrest/gear lever/heel guard assembly off ebay, choosing one from a 2000 bike that matches my own. When fitting it, I found it wouldn't fit as the gear lever is straight, whereas my one is slightly S shaped. I've looked on ebay for more examples, but it's a bit of a minefield of mis-information. It looks like the S lever is from Gen2 bikes, but then why is it on my Gen1? Does anyone know what years/models the straight lever is from, so I can resell it with an accurate description? Re: Gear lever confusion - YamFazFan - 12-12-14 I thought they all have the gear lever with the bend in it (??). Re: Gear lever confusion - darrsi - 12-12-14 Have a look on AJ Sutton website, per year. Re: Gear lever confusion - noggythenog - 12-12-14 Jamie ive got the complete assembly in my shed from when i stripped it. If you want ill take some pics of it later if it helps you see what it should look like as mine was off a 2001 that was manufactured in 2000. Nog Re: Gear lever confusion - Panthor - 12-12-14 do you have a link to the ebay add that you bought from or a pic of the one you bought? Re: Gear lever confusion - Jamieg285 - 12-12-14 http://www.ebay.co.uk/itm/231390063929 I'm wondering if a previous owner has straightened it for some reason? It would be OK, but I have crash bars that mount on the same bolts as the hangers, and have less clearance. If it's not as it should be, I won't bother trying to flog it. Re: Gear lever confusion - YamFazFan - 12-12-14 That lever doesn't look right.If your existing lever assembly is ok,can't you just fit the footpeg from the e-bay assembly to that?. Re: Gear lever confusion - Jamieg285 - 12-12-14 Already done all that, I'm just trying to work out if I can sell the straight one. Re: Gear lever confusion - fazersharp - 12-12-14 Something like this came up earlier in the year have a look here with pictures http://foc-u.co.uk/index.php/topic,10237.msg106648.html#msg106648 Re: Gear lever confusion - YamFazFan - 12-12-14 So it seems like it's been straightened to try to accommodate a rider with bigger feet?. |
