Speedo issue - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Speedo issue (/showthread.php?tid=71076) |
Speedo issue - Kentish - 09-12-14 Hello all My speedo stopped working today. It was fine yesterday!! The lugs don't look broken on the speedo drive. The Odo works fine as does the Rev counter and fuel gauge I can't remember on the fazer of the needles go right up and down when you first turn the bike on? Anyone know of a fix for this problem?? Ta Kentish Re: Speedo issue - red98 - 09-12-14 If the lugs are ok next thing to check is the lead that runs from the wheel to the clocks.make sure its not trapped anywhere or rubbing on something.check closely around the brake caliper............ Re: Speedo issue - Kentish - 09-12-14 I have checked the lead and that is ok Also. Not trapped anywhere etc Also done a tips check and it reads 5000k which I understand is all correct Re: Speedo issue - Jules-C - 09-12-14 You say the odo is fine, so the mileage reading gets higher as you drive along the road? In that case the sensor and wiring is OK. Sounds like it is the speedo head itself that's the problem. The needles don't do a sweep test when you turn the ignition on Re: Speedo issue - fazersharp - 09-12-14 (09-12-14, 02:29 PM)Jules-C link Wrote: Y Sounds like it is the speedo head itself that's the problem. The needles don't do a sweep test when you turn the ignition onMy 98 boxeye doesn't do a needle sweep Re: Speedo issue - Kentish - 09-12-14 I have just checked the odo and it's not recording mileage now Re: Speedo issue - BBROWN1664 - 09-12-14 If the ODO isn't working and the lugs are fine, look for a chaffed wire between the hub and the head unit. Re: Speedo issue - Kentish - 09-12-14 Hello all, thanks for those that replied to my post you are appreciated, When we mention lugs here are we talking about the ones that located the speedo drive on the fork leg? Or are there ones inside the actual speedo drive? I havn't taken the wheel off and looked inside the drive? Re: Speedo issue - red98 - 09-12-14 Ah......you need to take the wheel out to look at the lugs........common problem on these bikes... Re: Speedo issue - Kentish - 09-12-14 Oh really, I wondered why fowlers have 57 in stock and my local dealer that doesn't stock anything has one in stock. It must be a problem, I will investigated and let you all no. Thanks everyone Re: Speedo issue - darrsi - 09-12-14 (09-12-14, 10:33 PM)Kentish link Wrote: Oh really, I wondered why fowlers have 57 in stock and my local dealer that doesn't stock anything has one in stock. It must be a problem, I will investigated and let you all no. Thanks everyone Fowlers supply bike shops as well with original parts, that's why they'll have a lot of stock. Re: Speedo issue - Deefer666 - 10-12-14 I normally have at least two in stock at any one time. they are know for breaking up, especially if someone who does not know about them has the wheel out. Re: Speedo issue - Kentish - 10-12-14 Well I rode in this morning and it started working again all of 1min then it's stopped again!! I haven't had time to take the wheel off and look yet though Re: Speedo issue - Kentish - 11-12-14 (09-12-14, 10:08 PM)red98 link Wrote: Ah......you need to take the wheel out to look at the lugs........common problem on these bikes... That was the problem. Broken lugs. Replaced the rotor. Fixed. thanks all Re: Speedo issue - red98 - 11-12-14 Well done matey....another fazer fixed by FOC..... :thumbup |
