carburator mixture screw adjustment - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: carburator mixture screw adjustment (/showthread.php?tid=71048) |
carburator mixture screw adjustment - kevt - 06-12-14 Hi can anyone tell where and what sort of screwdriver I need to adjust the fuel mixture with the carbs still fitted. Have looked at right angled screwdriver but not sure if they will fit thanks for your help kev Re: carburator mixture screw adjustment - Falcon 269 - 06-12-14 You need a special 90 deg 'driver for this job - most you find Halfords and other tool shops aren't thin enough to get at the carbs over the starter motor. Not cheap.
Re: carburator mixture screw adjustment - Andy FZS - 07-12-14 Is that a screwdriver that's bent or one with a ratchet type mechanism Re: carburator mixture screw adjustment - Tmation - 07-12-14 You need one of these http://www.amazon.com/Motorcycle-Mixture-Carburetor-Adjusting-Degree/dp/B005SUU2HS Or from the UK [size=78%]http://www.amazon.co.uk/Laser-5067-Mixture-Screw-Adjuster/dp/B00449EJHS/ref=sr_1_fkmr1_1?ie=UTF8&qid=1417951104&sr=8-1-fkmr1&keywords=Motorcycle+Tool+Air+Mixture+Carburetor+Pilot+Screw+Adjusting+Tool+90+Degree[/size] http://www.amazon.co.uk/Sealey-MS013-Pilot-Screw-Adjusting/dp/B004LY73NS/ref=pd_sim_sbs_auto_1?ie=UTF8&refRID=1Y92WTDCKP7266EEB20P Or the big boys version [/size][size=78%]http://www.amazon.co.uk/Sealey-VS0530-Driver-Carburettor-Adjustment/dp/B000WZH416/ref=pd_sim_sbs_diy_3?ie=UTF8&refRID=1MZY13QES85Q9V23AST6[/size] |
