Rear linkage - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Rear linkage (/showthread.php?tid=71042) |
Rear linkage - nivek24 - 05-12-14 Putting the rear shocker back on, should the linkage be tightened up with the bike on the stand or off the stand. or does it not matter. thanks. :\ kevin Re: Rear linkage - PieEater - 05-12-14 I believe you get less play if you tighten the bolts with the bike on the side stand. Re: Rear linkage - solorider - 06-12-14 Shouldn't make no difference as the bearings are roller bearings. Re: Rear linkage - unfazed - 06-12-14 (06-12-14, 02:33 PM)solorider link Wrote: Shouldn't make no difference as the bearings are roller bearings. :thumbup Does not matter as they are tightened onto the collar/spacer not the needle roller bearings Re: Rear linkage - solorider - 08-12-14 (06-12-14, 07:06 PM)unfazed link Wrote: [quote author=solorider link=topic=15455.msg176446#msg176446 date=1417872832] :thumbup Does not matter as they are tightened onto the collar/spacer not the needle roller bearings [/quote] it is nothing to with having a collar/spacer as bushes also have a spacer, a bearing can be tightened in any position but a rubber bush should be tightened in its resting position under load otherwise the rubber bonding will get damaged when moved to its working position, not that will affect many motorcycles. Re: Rear linkage - Simon.Pieman - 08-12-14 (06-12-14, 07:06 PM)unfazed link Wrote: [quote author=solorider link=topic=15455.msg176446#msg176446 date=1417872832] :thumbup Does not matter as they are tightened onto the collar/spacer not the needle roller bearings [/quote] I agree, but oddly the play in the linkage (which you can feel by lifting the back wheel) is slightly less if you tighten the linkage bearings up with the bike on the side stand as opposed to the centre stand. I have no idea why it turns out this way but I seen it myself a couple of times. Bit of a headscratcher..... Re: Rear linkage - solorider - 15-12-14 (08-12-14, 10:27 AM)Simon.Pieman link Wrote: [quote author=unfazed link=topic=15455.msg176476#msg176476 date=1417889165] :thumbup Does not matter as they are tightened onto the collar/spacer not the needle roller bearings [/quote] I agree, but oddly the play in the linkage (which you can feel by lifting the back wheel) is slightly less if you tighten the linkage bearings up with the bike on the side stand as opposed to the centre stand. I have no idea why it turns out this way but I seen it myself a couple of times. Bit of a headscratcher..... [/quote] I tightened mine up on the main stand and I have no play in my linkages Re: Rear linkage - Simon.Pieman - 16-12-14 (15-12-14, 08:27 PM)solorider link Wrote: I tightened mine up on the main stand and I have no play in my linkages There's a chance you've done it too tight then. Even from new these linkages have a perceptible play in them when you lift the swingarm. |
