parts catalogue and model numbers - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: parts catalogue and model numbers (/showthread.php?tid=70912) |
parts catalogue and model numbers - MC680x0 - 16-11-14 so the parts catalog in the downloads section, refers to FZS600/(295DM-300E2) a quick check on wikipedia (not sure how accurate this is) suggests models
ta Re: parts catalogue and model numbers - darrsi - 17-11-14 A very high amount of parts are compatible on these bikes, hence the reason most breakers list them as 98-03. It would be mainly fairings, tank, etc that would be different, although even tanks can be swapped over without too much fuss. Re: parts catalogue and model numbers - MC680x0 - 17-11-14 Quite. But not quite the answer sought. Bit of background... I asked because I had a bar off a guy on here which was off a fiz but was not the same as that which I removed. The locating holes for switch gear were in different places. The 'serated' bits around the middle of the bars was in different locations. This made me wonder and postulate that there are subtle differences across the model range and different part numbers... So what are the definitive list of varying parts and respective numbers Re: parts catalogue and model numbers - darrsi - 17-11-14 To be honest I doubt you'll ever get that answer in full on here. Re: parts catalogue and model numbers - MC680x0 - 17-11-14 Mmmm. You never know. Worth asking and certainly something to be aware of Re: parts catalogue and model numbers - YamFazFan - 18-11-14 (16-11-14, 10:26 PM)tweetytek link Wrote: so the parts catalog in the downloads section, refers to FZS600/(295DM-300E2) so where does the "295DM-300E2" come from Is '295DM-300E2' the part number for the actual catalogue itself I wonder?. Re: parts catalogue and model numbers - MC680x0 - 18-11-14 ??? Could well be Re: parts catalogue and model numbers - darrsi - 18-11-14 (18-11-14, 08:37 PM)YamFazFan link Wrote: [quote author=tweetytek link=topic=15316.msg174048#msg174048 date=1416173198] Is '295DM-300E2' the part number for the actual catalogue itself I wonder?. [/quote] You're right, it's the catalogue production number! Re: parts catalogue and model numbers - YamFazFan - 18-11-14 The catalogue shows the fairing parts for the boxeye model only.I'm guessing that there must be other,revised/updated catalogues for the foxeye models.I have seen a different model code for 2002/3 elsewhere as well..5RT4. |
