Red Rubber Grease & Copper grease - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: For Sale & Wanted (https://foc-u.co.uk/mybb/forumdisplay.php?fid=80) +--- Thread: Red Rubber Grease & Copper grease (/showthread.php?tid=70848) |
Red Rubber Grease & Copper grease - Dave48 - 08-11-14 For anyone contemplating brake service/overhaul I can supply 20gm tins of these. Red Rubber Grease OR copper grease (1 tin) cost £2 posted Both products 2 tins) £3 posted Paypal preferred. PM me if interested. Re: Red Rubber Grease & Copper grease - Dave48 - 22-11-14 Still have a few tins of the above if anyone wants? Re: Red Rubber Grease & Copper grease - Andy Clap - 09-12-14 (08-11-14, 02:19 PM)Dave48 link Wrote: For anyone contemplating brake service/overhaul I can supply 20gm tins of these.Where is the red rubber grease used Dave? What's used for the swingarm pivot? Re: Red Rubber Grease & Copper grease - JoeRock - 10-12-14 Red rubber grease is used for the brake pistons mate. YOu could use it for the swingarm but its a bit pointless - normal lithium grease is whats normally used on bearings as its good and cheap! Re: Red Rubber Grease & Copper grease - Dave48 - 10-12-14 (10-12-14, 10:09 AM)JoeRock link Wrote: Red rubber grease is used for the brake pistons mate. YOu could use it for the swingarm but its a bit pointless - normal lithium grease is whats normally used on bearings as its good and cheap! As Joe says,Andy. A light smear of redrubbergrease on the outside of the brake caliper pistons,helps keep out the water & s**t that eventually leads to seizing/sticking brake pistons, also helps piston/rubber seal interface. Copper grease on back of brake pads(sparingly) and on any fastener that might be liable to corrode /seize-again only v. little needed. Steering bearings, swing arm & rear suspension pivots-Lithium based grease as per Yamaha manual. Re: Red Rubber Grease & Copper grease - wheelywill - 10-12-14 Hi i will take a tin of each if you have any left Cheers Dave
Re: Red Rubber Grease & Copper grease - Dave48 - 10-12-14 (10-12-14, 08:13 PM)wheelywill link Wrote: Hi i will take a tin of each if you have any left Cheers DavePM sent, Dave48 |
