[Technical] Steering feeling very light [Solved] - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: [Technical] Steering feeling very light [Solved] (/showthread.php?tid=70830) |
[Technical] Steering feeling very light [Solved] - helloindustries - 06-11-14 Solved. Had it looked at. It was a loose bearing. Ahoy. Over the last week or so, my steering has felt way too light. I've checked the tyre pressures, and they're correct. I've yet to take it in for a once-over at the garage, though. It could be the position/angle of the bars as i have Renthals (756) on a 1 inch riser set, and they're rotated back a touch for comfort, but the lightness in the steering seems to have only popped-up recently, and i've had the bars/bike for just over 5 months now. Certainly feels lighter with left turns compared to right, which leads me to think it might be a bearing issue. I think i'm looking to get some pointers on areas to check. Re: [Technical] Steering feeling very light - red98 - 06-11-14 Ok, this might sound a bit strange but....have you checked the pressures in both the front and back ?...low pressure in the rear can cause these symptoms. .......... Re: [Technical] Steering feeling very light - Exupnut - 06-11-14 Fuck All.... Sorry Fork Oil Re: [Technical] Steering feeling very light - BBROWN1664 - 06-11-14 Rear pre load can affect it too Re: [Technical] Steering feeling very light - helloindustries - 06-11-14
Re: [Technical] Steering feeling very light - His Dudeness - 06-11-14 Could be the headstock bearing. If you hold the front brake on and give the bars a good seeing too like they've just stolen your lunch money is there any up and down movement, looseness or clicking sounds? Re: [Technical] Steering feeling very light - helloindustries - 06-11-14 (06-11-14, 10:56 PM)His Dudeness link Wrote: Could be the headstock bearing. If you hold the front brake on and give the bars a good seeing too like they've just stolen your lunch money is there any up and down movement, looseness or clicking sounds? I shall check that tomorrow. I've been wanting to put it through a mock-MOT anyway, seems like a good opportunity. Re: [Technical] Steering feeling very light - darrsi - 07-11-14 If you do change fork oil, go for 15w instead of standard 10w oil, you will notice a big improvement. Re: [Technical] Steering feeling very light - helloindustries - 07-11-14 (07-11-14, 02:33 PM)darrsi link Wrote: If you do change fork oil, go for 15w instead of standard 10w oil, you will notice a big improvement. I shall keep that in mind. Got it looked at. Bearing was loose. Seems to have fixed it. Re: [Technical] Steering feeling very light [Solved] - His Dudeness - 08-11-14 If it goes loose again you'll have to replace it |
