Bike wobble out of corners/with speed - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Bike wobble out of corners/with speed (/showthread.php?tid=70764) |
Bike wobble out of corners/with speed - papercutout - 31-10-14 I've had this for a while now, but finally decided I need to get it sorted! If I hit a bump mid corner, the bike gets a lovely (read; scary) wobble on when travelling at a reasonable speed. Even worse is that if you get to around 100 leptons and are accelerating but not gripping the tank hard with your leg, it also gets a big wobble. I've just had the front wheel rebalanced, and that hasn't helped. A little while ago I changed swingarm and fitting new bearings, that didn't fix it (but my new swingarm is powdercoated black, so that's a plus!) Has anyone got any suggestions? I only weigh 60kg's and it's better with more weight, but my old one didn't do it. Thanks Re: Bike wobble out of corners/with speed - noggythenog - 31-10-14 Hey papercut My bike knowledge is limited but i do like a good ol shoot from the hip guess........well it is a forum after all aint it he he. :lol Anyway i was just about to throw out my best "feeling the force" guess but then i thought hang on a minute :think Which part is getting a wobble on?.......is it the front end, the rear end......or have you got a big fat moma riding pillion with her ass cheeks getting a wobble on? :b Re: Bike wobble out of corners/with speed - darrsi - 31-10-14 What's the mileage? Ever done anything with the rear shock? Re: Bike wobble out of corners/with speed - stevierst - 31-10-14 What bike is it your on? If it's a 600, then some of them do that. I've had 3, and 2 of them have had shaky heads. There's loads of little things it could be. Worn tyre (front or back), Knackered wheel bearing, Back wheel out of line, Worn fork (low oil, snapped spring?) Swing arm/link bushes, Buggered shock. It's trial and error to find it. Re: Bike wobble out of corners/with speed - MC680x0 - 01-11-14 Mine does the same. At low speed with fingers just raised off the bar, the bar wobbles left to right with increasing oscillation. I Raised similar questions when I first got the fzs600. Lots of foccers reported sane thing. There is even an article on it in hotpoop. I too have had the balance done up front and full checks at the mechanics. I just live with it now but it is the only characteristic that puts me off these models Re: Bike wobble out of corners/with speed - His Dudeness - 01-11-14 This sounds worse than the normal little bit of front wheel wobble. Could be the head stock bearings Re: Bike wobble out of corners/with speed - darrsi - 01-11-14 (01-11-14, 10:25 AM)His Dudeness link Wrote: This sounds worse than the normal little bit of front wheel wobble. Could be the head stock bearings When the oil leaked out of my rear shock the bike was going round corners with just the shock spring supporting me and the bike. Proper wobbles. Re: Bike wobble out of corners/with speed - darrsi - 01-11-14 (01-11-14, 08:37 AM)tweetytek link Wrote: Mine does the same. At low speed with fingers just raised off the bar, the bar wobbles left to right with increasing oscillation. I Raised similar questions when I first got the fzs600. Lots of foccers reported sane thing. There is even an article on it in hotpoop. I too have had the balance done up front and full checks at the mechanics. I just live with it now but it is the only characteristic that puts me off these models Are you sure it's not just you? You've had an off at 10mph and also managed to wreck your indicators parking between 2 bikes! Re: Bike wobble out of corners/with speed - His Dudeness - 01-11-14 (01-11-14, 10:39 AM)darrsi link Wrote: [quote author=His Dudeness link=topic=15168.msg171944#msg171944 date=1414833956] When the oil leaked out of my rear shock the bike was going round corners with just the shock spring supporting me and the bike. Proper wobbles. [/quote] Scary stuff. That's the sort of thing that causes crashes Re: Bike wobble out of corners/with speed - scoobie_paws - 01-11-14 Sounds like rear shock damping away to me. Had same thing on mine, especially when accelerating hard up hill,whole thing would shoogle about and was a bit scary.replaced rear shock (r6 from kebab) and is soooo much better. Also changed fork oil and that gave some much needed damping to the front too Re: Bike wobble out of corners/with speed - darrsi - 01-11-14 (01-11-14, 10:57 AM)His Dudeness link Wrote: [quote author=darrsi link=topic=15168.msg171949#msg171949 date=1414834785] When the oil leaked out of my rear shock the bike was going round corners with just the shock spring supporting me and the bike. Proper wobbles. [/quote] Scary stuff. That's the sort of thing that causes crashes [/quote] It felt like the rear tyre was sliding momentarily on bends, and i would immediately adjust steering to compensate, as if i was riding a speedway bike. Used to wake me up in the mornings though. :lol Re: Bike wobble out of corners/with speed - papercutout - 02-11-14 (01-11-14, 11:19 AM)darrsi link Wrote: [quote author=His Dudeness link=topic=15168.msg171955#msg171955 date=1414835824] When the oil leaked out of my rear shock the bike was going round corners with just the shock spring supporting me and the bike. Proper wobbles. [/quote] Scary stuff. That's the sort of thing that causes crashes [/quote] It felt like the rear tyre was sliding momentarily on bends, and i would immediately adjust steering to compensate, as if i was riding a speedway bike. Used to wake me up in the mornings though. :lol [/quote] I had this a couple of weeks ago, only I'd also get wheelspin when accelerating. I concluded I rode through some oil or similar on my journey home at night, it was terrifying! Normal speed down to a max of 50mph... [size=1em]stevierst, it's a 600. Regarding your points: The front tyre is nearly new. The rear tyre was replaced a few thousand miles back, and is getting slightly flat in the middle, but it did it before too. Shouldn't be, just had it MOT'd (non-dodgy) and no comments were made on them. Again, shouldn't be. Wobbled before I changed the swingarm, and before the new chain, and it's definitely been realigned. Not needed adjusting since I got a working scottoiler either. The front forks failed MOT due to being too stiff, took a little oil out of each. Wobble both before and after. Swing arm and link bushes mostly new. I guess I might have a buggered shock. Seemed OK when I removed it, but didn't check in detail, I might play with the preload and see if anything changes.[/size] Re: Bike wobble out of corners/with speed - MC680x0 - 02-11-14 (01-11-14, 10:42 AM)darrsi link Wrote: [quote author=tweetytek link=topic=15168.msg171937#msg171937 date=1414827475] Are you sure it's not just you? You've had an off at 10mph and also managed to wreck your indicators parking between 2 bikes! [/quote] :rollin And this is just on a fiz that i've had for about a year. Countless other bikes and woes Re: Bike wobble out of corners/with speed - darrsi - 02-11-14 (02-11-14, 09:00 PM)papercutout link Wrote: [quote author=darrsi link=topic=15168.msg171957#msg171957 date=1414837163] When the oil leaked out of my rear shock the bike was going round corners with just the shock spring supporting me and the bike. Proper wobbles. [/quote] Scary stuff. That's the sort of thing that causes crashes [/quote] It felt like the rear tyre was sliding momentarily on bends, and i would immediately adjust steering to compensate, as if i was riding a speedway bike. Used to wake me up in the mornings though. :lol [/quote] I had this a couple of weeks ago, only I'd also get wheelspin when accelerating. I concluded I rode through some oil or similar on my journey home at night, it was terrifying! Normal speed down to a max of 50mph... [size=1em]stevierst, it's a 600. Regarding your points: The front tyre is nearly new. The rear tyre was replaced a few thousand miles back, and is getting slightly flat in the middle, but it did it before too. Shouldn't be, just had it MOT'd (non-dodgy) and no comments were made on them. Again, shouldn't be. Wobbled before I changed the swingarm, and before the new chain, and it's definitely been realigned. Not needed adjusting since I got a working scottoiler either. The front forks failed MOT due to being too stiff, took a little oil out of each. Wobble both before and after. Swing arm and link bushes mostly new. I guess I might have a buggered shock. Seemed OK when I removed it, but didn't check in detail, I might play with the preload and see if anything changes.[/size] [/quote] The general consensus on here is that they tend to last around 20,000 miles before needing some sort of attention, or replacing. Re: Bike wobble out of corners/with speed - papercutout - 10-11-14 The bike is on about 27k now, so that might be a partial explanation. I adjusted the rear spring so it's not at full preload, it's 3 clicks down (middle) now, and that has helped! Re: Bike wobble out of corners/with speed - JoeRock - 10-11-14 (10-11-14, 01:38 PM)papercutout link Wrote: The bike is on about 27k now, so that might be a partial explanation. It's not really gonna sort it though mate if the dampings gone. They're not a great shock to start with, and at 27k it won't be anywhere near where it started! Re: Bike wobble out of corners/with speed - Arfa - 10-11-14 Maybe stating obvious, but I presume your tyre pressures are good? Also as your pretty light weight, you may find manual specified pressures a spot high, which can cause some skittish behaviour. Rear shock maybe more likely, but check the cheap and easy stuff first. Re: Bike wobble out of corners/with speed - Exupnut - 10-11-14 My Mrs had the same problem on her FZ6. She said the rear just didnt feel planted. We tried adjusting the shock and dropping the front forks and bought a lowering kit for it but u know what sorted it....Lipo Suction Re: Bike wobble out of corners/with speed - papercutout - 10-11-14 (10-11-14, 10:12 PM)Exupnut link Wrote: My Mrs had the same problem on her FZ6. She said the rear just didnt feel planted. We tried adjusting the shock and dropping the front forks and bought a lowering kit for it but u know what sorted it....Lipo Suction But I've got nothing to lose! :p Thanks guys, Arfa - they're already slightly lower, 34-38 maybe? |
