Clock - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Clock (/showthread.php?tid=70736) |
Clock - Pal - 28-10-14 Seeing as the clocks have gone back, and I don't have a manual or handbook, can anyone tell me how to change the clock? Re: Clock - Pal - 28-10-14 Just found this, must look harder next time. Posted in case anyone else needs it Clock mode To change the display to the clock mode, push the “SELECT” button. To change the display back to the odometer mode, push the “SELECT” button. To set the clock 1. Push both the “SELECT” and “RESET” buttons for at least two seconds. 2. When the hour digits start flashing, push the “RESET” button to set the hours. 3. Push the “SELECT” button to change the minutes. 4. When the minute digits start flashing, push the “RESET” button to set the minutes. 5. Push the “SELECT” button to start the clock. NOTE: @ After setting the clock, be sure to push the “SELECT” button before turning the main switch to “OFF”, otherwise the clock will not be set. |
