[compatibility] FZ1 (2001) Rear brake calliper > FZS600 (1999) - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: [compatibility] FZ1 (2001) Rear brake calliper > FZS600 (1999) (/showthread.php?tid=70709) |
[compatibility] FZ1 (2001) Rear brake calliper > FZS600 (1999) - helloindustries - 24-10-14 Just a thought at this point. Thinking of replacing the rear brake calliper on my '99 Fizzy with an FZ1 rear brake calliper. Why? Cosmetic reasons. The front and rear brake callipers don't match. The rear is a generic looking calliper. Would i also need the bracket for an FZ1 rear brake? Re: [compatibility] FZ1 (2001) Rear brake calliper > FZS600 (1999) - Arfa - 24-10-14 Nope, stick with FZS600 bracket. FZ1 bracket isn't compatible. FZS600 hose fits. If you fancy the matching tension/torque arm, you'll need the one off an Thunderace. Re: [compatibility] FZ1 (2001) Rear brake calliper > FZS600 (1999) - helloindustries - 24-10-14 (24-10-14, 10:46 PM)Arfa link Wrote: Nope, stick with FZS600 bracket. FZ1 bracket isn't compatible. Cool, so: Calliper from an FZ1 IS compatible and WILL fit existing FZS600 bracket Bracket is NOT ? Re: [compatibility] FZ1 (2001) Rear brake calliper > FZS600 (1999) - Arfa - 24-10-14 Yes and yes. But fzs600 bracket needs a little filing off and you'll need a couple of washers to centre caliper. Ive put post on my blog with some snaps or search past posts on here as others had some good pics too. Re: [compatibility] FZ1 (2001) Rear brake calliper > FZS600 (1999) - helloindustries - 24-10-14 (24-10-14, 11:06 PM)Arfa link Wrote: Yes and yes. But fzs600 bracket needs a little filing off and you'll need a couple of washers to centre caliper. Ive put post on my blog with some snaps or search past posts on here as others had some good pics too. Thanks, had a look through, found the info. Appreciated. Re: [compatibility] FZ1 (2001) Rear brake calliper > FZS600 (1999) - Chris - 25-10-14 Make sure you're getting the right caliper. The FZ1 caliper wont fit. only the blue spot one from the fzs1000 01-05 will fit. Chris Re: [compatibility] FZ1 (2001) Rear brake calliper > FZS600 (1999) - helloindustries - 25-10-14 (25-10-14, 01:44 AM)Chris link Wrote: Make sure you're getting the right caliper. Thanks for the heads-up on that! Re: [compatibility] FZ1 (2001) Rear brake calliper > FZS600 (1999) - papercutout - 26-10-14 Nor will an old R1 caliper, so don't mis-read! (Although I eventually did fit it, I had to do some adapting) |
