Finding Neutral - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Finding Neutral (/showthread.php?tid=70663) |
Finding Neutral - coolhandluke - 19-10-14 Hi Guys / Gals, during a chain and sprocket change, ive taken the front sprocket cover off get at the sprocket and in doing so had to take off the gear linkage lever. i tried to score it so finding the correct position when reassembling it wouldnt be an issue but i didnt do it very well. tried to find the correct position and its no longer in neutral and i cant find neutral when trying to come through the gears. has anybody had this before and what did you do!! thanks in Advance! Re: Finding Neutral - coolhandluke - 19-10-14 Ive sorted it. the sprocket had turned slightly so i just put it back to its original position and it poped back into neutral. hope this will help any other numpties like me Re: Finding Neutral - Deefer666 - 19-10-14 if you clean the crud off, there is a dot punched into the end of the gear shaft. Use that to align the selector mechanism. |
