running problems - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: running problems (/showthread.php?tid=70650) |
running problems - king1 - 17-10-14 My bike is running like a bag of s##te At normal speeds it is ok but at motorway speeds the engine is like it is stuttering no power power even drops off you start off with a full fuel tank and it drops down fast, when you open it there is a fair vacuum at the moment I am tuning in the carbs and building a balancing tool, to check the balancing all my local garages are not interested in looking at it What do I need to look at and do??? Thanks you can tell a happy biker by the flies in his teeth Re: running problems - Dave48 - 17-10-14 Whats your air filter looking like? Re: running problems - unfazed - 17-10-14 As above check the air filter first Re: running problems - Frosties - 17-10-14 (17-10-14, 07:00 PM)king1 link Wrote:At normal speeds it is ok but at motorway speeds You need to keep an eye on rev counter & change up to 3rd fella :lol Re: running problems - darrsi - 17-10-14 Could be an air leak, are your carb rubbers in good nick? Re: running problems - MC680x0 - 17-10-14 If it were filter problems then the bike would struggle at idle Check carbs, jets, ignition timing at say 5k, rubbers, etc Re: running problems - andybesy - 17-10-14 You say there is a vacuum in tank after running a while? Maybe check breather hoses, could cause fuelling issues if blocked. You had tank off recently? Andy Re: running problems - andybesy - 17-10-14 To check carb rubbers you can inspect visually but then also spray carb or brake cleaner on them and listen if idle picks up, if so then air leak. Also check plugs condition and colour lots of clues to be found there. Re: running problems - MC680x0 - 17-10-14 :thumbup (17-10-14, 10:25 PM)andybesy link Wrote:To check carb rubbers you can inspect visually but then also spray carb or brake cleaner on them and listen if idle picks up, if so then air leak. Also check plugs condition and colour lots of clues to be found there. Re: running problems - BBROWN1664 - 18-10-14 Quote:you start off with a full fuel tank and it drops down fast, when you open it there is a fair vacuum That is the symptoms of blocked tank breather hoses. Re: running problems - king1 - 18-10-14 Right I am banging my head against a brick wall I am lucky if I can do 60mph all plugs sooted up I am getting no where is there anyone in the Manchester area who could give me some help or a pillow for the wall Re: running problems - BBROWN1664 - 18-10-14 Gently lift the tank and check the breather hoses (close to seat on off-side) are not kinked or blocked. If they are, you will get a vacuum in the tank. To test this theory, open the tank cap and ride like that for a bit. If alls well doing this you definitely have a problem with the breather pipes. Re: running problems - darrsi - 18-10-14 (18-10-14, 04:47 PM)king1 link Wrote:Right I am banging my head against a brick wall You've not actually answered anyone's questions? Sooty plugs is normally caused by unburned fuel, so either too much fuel or not enough air. How old is your air filter, and more importantly what brand did you last put in? You say you're tuning the carbs, but what exactly are you doing? Give us as much info as possible no matter how trivial, like have you had any recent work done on it, or changed anything? Re: running problems - andybesy - 19-10-14 Yup sooty plugs could be a symptom of the original problem OR whatever adjustments you've made to the carbs since. I'd put carbs back to standard and check plugs again, and also investigate tank vacuum and check filter. Were all four plugs the same? Let us know how you get on. Andy |
