Balance weights - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Balance weights (/showthread.php?tid=70641) |
Balance weights - midden - 16-10-14 Checking tyre pressures today I found the weights have fallen off the rear wheel. i've not noticed any effect on handling during my commute. Is it worth taking wheel in to be rebalanced? Re: Balance weights - Grahamm - 16-10-14 How much would a quick check for balance cost? How much would it cost if it suddenly started to wobble at speed and you dropped it...? Re: Balance weights - chaz - 16-10-14 Its not that important on the rear wheel, if you've less than half the tread left leave it till next new tyre, it can go out of balance as it wears down anyway but how many have there tyres rebalanced? if you're riding close to the limits then it could be worth while. up to you? Re: Balance weights - Simon.Pieman - 16-10-14 (16-10-14, 10:12 PM)Grahamm link Wrote:How much would a quick check for balance cost? I don't think there is a need to be alarmist, this is not a serious problem. A front wheel out of balance might cause consternation at moderate speeds and perhaps roadholding issues at higher speed but the rear is far less critical when it comes to balance and certainly won't cause you to drop it, the effect isn't that dramatic. Best thing to do is take the wheel out, put the axle back through and set it up on two axle stands and balance it yourself, there are lots of 'how to' vids on Youtube, it's easy, a 15 minute job. You don't even really need the proper weights, I hacksaw old fishing weights up and bash them flat with a hammer and fix then to the wheel with ductape. There is something nicely therapeutic about balancing a wheel, do try it. Re: Balance weights - midden - 16-10-14 Ooo what a good idea, does Ducktape work well then Re: Balance weights - Simon.Pieman - 17-10-14 (16-10-14, 11:51 PM)midden link Wrote:Ooo what a good idea, does Ducktape work well then I've never had any fall off, in fact it is an effort to remove. Re: Balance weights - tony_d123 - 17-10-14 (16-10-14, 10:35 PM)Simon.Pieman link Wrote:You don't even really need the proper weights, I hacksaw old fishing weights up and bash them flat with a hammer and fix then to the wheel with ductape. Shouldn't that be in the tightwads thread They are cheap enough on eBay. Re: Balance weights - Simon.Pieman - 17-10-14 (17-10-14, 03:16 PM)tony_d123 link Wrote:They are cheap enough on eBay. Mine don't fall off. Re: Balance weights - VNA - 17-10-14 I've run a couple of rears unbalanced and you don't notice any difference. It is probably best practise to balance me though. With a front you will notice if it's badly out. So, personally, I'd just run it till the tyres done. Re: Balance weights - unfazed - 17-10-14 "Its not that important to balance the rear wheel" is a very common misconception. :rolleyes Balancing the wheel/tyre does 2 things Reduce vibration which increases grip levels Reduce tyre wear over the life of the tyre. An unbalanced wheel/tyre will cause vibration and can effect grip especially on wet/damp surface and the faster you go the worse it gets, the tyre also wears faster as the heavest part of the tyre will wear faster as it tries to bring the Wheel/tyre closer to balance. Look at the wear on an unbalanced tyre which would require 30 or more grams to balance it, part will be worn completely while the rest will be well within the wear limit. I have seen tyres worn to 1mm of thread at one point and have 4mm left on the rest. I have always balanced both front and rear on any bike capable of more than 50 MPH If you lose more than 5 grams, then you should rebalance the wheel/tyre. Prior to balancing and changing my own bike tyres I always insisted that front and rear were balanced and any knowledgeable tyre fitter will do it without question. Many times I had to insist that fitters balance the front and rear wheels/tyres of my car also. The garage I now go to for car tyres, change the valves, balances all wheel/tyres and uses a torque wrench to tighten the nuts on the alloy wheels. :thumbup Re: Balance weights - Simon.Pieman - 17-10-14 (17-10-14, 09:19 PM)unfazed link Wrote:"Its not that important to balance the rear wheel" is a very common misconception. :rolleyes Rubbish. Where did you cut and paste this nonsense from? |
