Do Fazer 1000 levers fit FZS600 (1998) Mounts? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Do Fazer 1000 levers fit FZS600 (1998) Mounts? (/showthread.php?tid=70611) |
Do Fazer 1000 levers fit FZS600 (1998) Mounts? - helloindustries - 13-10-14 Mostly i'm asking because it's nigh-impossible to find some nice CNC'd levers for the latter, but there's plenty out there for the former. Re: Do Fazer 1000 levers fit FZS600 (1998) Mounts? - b1k3rdude - 16-10-14 As far as I am aware, yes. Re: Do Fazer 1000 levers fit FZS600 (1998) Mounts? - unfazed - 16-10-14 Yes, but the clutch lever will have has a bigger span due to the slightly different mount in the FZS1000 Re: Do Fazer 1000 levers fit FZS600 (1998) Mounts? - helloindustries - 16-10-14 (16-10-14, 07:24 PM)unfazed link Wrote:Yes, but the clutch lever will have has a bigger span due to the slightly different mount in the FZS1000 As in the lever will be a touch longer? Also: Just to be specific: For a 99 FZS 600. And this suggested Fazer thousand would be what; Similar year, no more than X? Re: Do Fazer 1000 levers fit FZS600 (1998) Mounts? - unfazed - 16-10-14 A touch longer and the distance from the bar to the lever at its furthest point is about 10mm extra. Probably would not be an issue with adjustable levers. Re: Do Fazer 1000 levers fit FZS600 (1998) Mounts? - helloindustries - 16-10-14 (16-10-14, 08:41 PM)unfazed link Wrote:A touch longer and the distance from the bar to the lever at its furthest point is about 10mm extra. Splendid. As soon as i can afford to do so, i'll be buying a set. Have a few other bits to attend to first: Seat needs leveling and re-covering, speedo mount needs some bending and moving to neaten it up, and so forth. It'd be extra awesome to be able to afford a Koso DB01+ too, but we'll see. Connecting it would be a whole other issue, too... Re: Do Fazer 1000 levers fit FZS600 (1998) Mounts? - helloindustries - 16-10-14 These seem OK. Just worried about import tax. A UK-based equivalent is £60. ![]() Re: Do Fazer 1000 levers fit FZS600 (1998) Mounts? - helloindustries - 16-10-14 Actually, this would suggest import tax would be very low. Excellent. |
