Throttle grip - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Throttle grip (/showthread.php?tid=70608) |
Throttle grip - Davew - 13-10-14 Why has my throttle grip suddenly gone slightly lose? It moves left and right slightly within the plastic throttle housing and is annoying as hell when riding. Can't seem to tighten anything up to stop it. Re: Throttle grip - Davew - 13-10-14 Is there a way to adjust the return throttle cable from the carb, as only the main throttle cable has an adjuster on it by the handlebars and that's not doing the trick. Re: Throttle grip - His Dudeness - 14-10-14 Yes there's adjuster on top of the carbs. Follow the cable down where they go into the carb and you'll see them. They're a bit awkward to get to. Re: Throttle grip - Davew - 14-10-14 bugger, thought that was it. Might leave that for a while then!
