Thread lock - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Thread lock (/showthread.php?tid=70560) |
Thread lock - ChristoT - 08-10-14 I use nyloc nuts instead. Or wirelocking. Re: Thread lock - slappy - 08-10-14 How do you fasten your brake discs on then? I would like to see the lock wiring on them, do you just drill a hole straight through the length of the bolt? Also there are many different types of "thread lock", where I work we have 5 different ones depending on the metals used, how often it might be taken apart, heat, vibration etc and I am sure there are probably many other types out there. Re: Thread lock - ChristoT - 08-10-14 I was being glib.
Re: Thread lock - BBROWN1664 - 08-10-14 disks on aircraft used to have the bolts drilled and wire locked. I guess the odd race bike may have that too. Personally, i'm a fan of friction. Re: Thread lock - locksmith - 08-10-14 I see what you did Christo ! Re: Thread lock - ChristoT - 09-10-14 (08-10-14, 05:10 PM)locksmith link Wrote: I see what you did Christo !
