Carbtunes in yorkshire - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Carbtunes in yorkshire (/showthread.php?tid=70532) |
Carbtunes in yorkshire - ajmes1 - 05-10-14 Would anyone near selby, north yorks, have a carbtune or similar that I could borrow along with a hand to balance the carbs? Getting an annoying vibration through the pegs between 6-7.5k revs in any gear and thought it's probably worth checking the balance. Re: Carbtunes in yorkshire - darrsi - 05-10-14 Double check engine mounting bolts are torqued correctly. Also have a look at how the centre stand rests on the end can link pipe as well, it may need a little adjustment as that could send vibes towards your feet, and obviously check that your exhaust bolts are all as they should be. Re: Carbtunes in yorkshire - Fazer Forever - 05-10-14 I've got some you can borrow, you know where I live! I'm busy the next couple of weekends though, then on holiday. Could give you a hand after that though if you need it. Re: Carbtunes in yorkshire - MC680x0 - 05-10-14 carbtune is for idle , the throttle links are adjusted to balance the carbs. At wider throttle the balancing insnt going to do that much, but it will improve like MPG I suppose. Check your mountings and fasteners and check the peg bolts are tight , probably need to take them off the bike at the bracket - only two bolts to remove. Check tank bolt near yolk and tank support rubbers Re: Carbtunes in yorkshire - ajmes1 - 07-10-14 Brill thanks for all the advice, And fazer forever, that would be great thanks, I'll drop you a pm in a few weeks if that suits. I can repay in beer etc. if required! Re: Carbtunes in yorkshire - Fazer Forever - 08-10-14 No probs, just give me a shout when you're ready. Re: Carbtunes in yorkshire - ste131 - 09-10-14 Any hassles with your bike then just call round. Im in Pudsey and have balancing kit. |
