Trip odometer reading - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Trip odometer reading (/showthread.php?tid=70354) |
Trip odometer reading - Pal - 19-09-14 Some of you may have seen my mileage thread, I didn't want to confuse anything by posting in there, the thing is my trip odometer don't seem to read right. When I filled up last time I set the second trip to 0, I have since done four trips to work, which is a 64 miles round trip (confirmed on my old bike, the car and bing maps). Now after these four trips I would have expected the trip meter to read 256 miles, but instead it reads 238. Has anyone else had this? I will check the front tyre size is correct as that could put the reading out. Incidentally this makes my mileage even more impressive
Re: Trip odometer reading - fazersharp - 19-09-14 (19-09-14, 01:18 PM)Pal link Wrote: I would have expected the trip meter to read 256 miles, but instead it reads 238. :think Thats just because the bike is quicker Re: Trip odometer reading - darrsi - 19-09-14 (19-09-14, 01:18 PM)Pal link Wrote: Some of you may have seen my mileage thread, I didn't want to confuse anything by posting in there, the thing is my trip odometer don't seem to read right. It won't be anything to do with the tyre. Re: Trip odometer reading - schlumpf - 19-09-14 That is about 7% low, very strange. Looks as if your tyre is larger than expected. The circumference should be 1840mm. You could simply measure the real value. The speed sensor gives 4 ticks per rotation. Any failure, or wrong sensor type, would give a much larger deviation. Last thing I could think of would be that the speed signals are electrically marginal and a few get lost from time to time. Re: Trip odometer reading - Yamazer-92 - 19-09-14 When I go to Wales with my dad we both set our trips at the start of the ride and also the start of each day. Every time, mine reads about 5% or so less than his however mine is always closer to the google maps estimated distance so we thought his was over reading? Re: Trip odometer reading - MC680x0 - 19-09-14 Mine does this although I only noticed after 250 mile trip to the in-laws. Error was about 3% not the 7% like yours which sounds quite a margin. I put it down to an old bike, old wiring, old ECU, old speed sensor - on my 2000 FZS. Doesnt bother me really, I mean we're talking about 7.5 miles out of 250. My daily commute is 26 miles round trip so that 0.78 miles error. Not worth bothering with - for me. Re: Trip odometer reading - Pal - 20-09-14 (19-09-14, 02:58 PM)darrsi link Wrote: It won't be anything to do with the tyre.If the tyre is the wrong aspect ratio it will be taller, therefore the circumference will be more giving a wrong reading for a given amount of revolutions of the wheel. Simple science. Re: Trip odometer reading - unfazed - 20-09-14 A 110/80 or 120/70 tyre would easily throw the clock out that much as both have a bigger circumference then the 110/70 Re: Trip odometer reading - darrsi - 20-09-14 (20-09-14, 08:47 PM)Pal link Wrote: [quote author=darrsi link=topic=14754.msg167146#msg167146 date=1411135107]If the tyre is the wrong aspect ratio it will be taller, therefore the circumference will be more giving a wrong reading for a given amount of revolutions of the wheel. Simple science. [/quote] You could always give us a clue as to what tyre you're using? Re: Trip odometer reading - Pal - 24-09-14 ![]() I think this might not help |
