 no lights - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: no lights (/showthread.php?tid=70304)  |
no lights - Sammyd240584 - 16-09-14 On way into work last night I discovered my headlight & taillight have stopped working, could only use headlight while holding the pass button in which made the ride to work a bit more interesting,checked the fuse & its ok, any ideas, its an 02 foxeye,its my only mode of transport at the minute so i need to sort it asap,thanks in advance Re: no lights - unfazed - 16-09-14 Did you check the fuses. There are 2 fuses in the light circuit: one supplies power to the relay which powers the lights and other supplies the power to the headlights. Re: no lights - Sammyd240584 - 16-09-14 I checked the fuse under the seat and swapped it for a new one, I also cleaned the terminals under the brake lever, the brake lights not working either, all ive got is indicators Re: no lights - positron - 16-09-14 Brake light or tail light? I mean, does the brake light come on when you brake? Re: no lights - unfazed - 16-09-14 Did you check the signal fuse? Second fuse from the right sitting on the bike. The headlight fuse is obviously OK as the headlights worked with the PA switch. The signal fuse controls the parking lights, brake lights, horn and relay for the headlights. The PA switches bypasses the relay and takes the power straight from the headlight fuse. Re: no lights - Sammyd240584 - 16-09-14 Good point unfazed, didnt even think of that, the joys of trying to think straight after a nightshift, lol, checked the signal fuse and it was blew, thank goodness was something simple, swapped it out and shes good to go,I am an idiot,thanks for the replies folks Re: no lights - unfazed - 16-09-14 And another happy Foccer :lol Re: no lights - Frosties - 16-09-14 (16-09-14, 08:02 PM)unfazed link Wrote: And another happy Foccer :lol Nice one unfazed, top bloke :thumbup :thumbup  |
