 Key help - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Key help (/showthread.php?tid=70200)  |
Key help - the cueball - 06-09-14 hi there... my fazer has developed an issue when I try to turn the key to the on position... well basically it won't do it. the key goes into the barrel no problem, and it turns to the left OK (for locking it) but it's now getting really hard to turn it on to be able to start the bike... it left me stranded for half an hour today before I managed to get it working... I only have 1 key, so can't try the other one.... but it sounds like a barrel issue? is this a common fault, and is there anything that can be done to fix it without the need for a new barrel?? thanks! :'( Re: Key help - darrsi - 06-09-14 Pull the steering fully to the left before pushing down and turning the key. Also, buy some of this stuff, you probably could find it in hardware shops too. It makes a big difference. [color=rgb(74, 74, 74)]http://www.amazon.co.uk/LUBRICANT-AEROSOL-SPRAY-PADLOCK-GRAPHITE/dp/B00BBTJ460/ref=sr_1_1?ie=UTF8&qid=1409921194&sr=8-1&keywords=key+lock+lube[/color] Re: Key help - midden - 06-09-14 I had same issue a while back but had a spare key to use instead. Re: Key help - mickvp - 06-09-14 take your key and get another one cut at Timpsons Cuey. The keys/barrels are made of cheese on these bikes, so a fresh key might work a bit better (the graphite spray above helps a lot too   )
Re: Key help - pilgo - 07-09-14 is your key even slightly bent? mine is,and it goes in the barrel fine,but can be a bugger to turn to the ON position,going to get 2 new keys cut on wednesday and just ordered some of that Grafite spray stuff,that might even make the steering lock work hopefully!! Re: Key help - the cueball - 07-09-14 cheers all... I dumped a half gallon of Gt85 in there and it's helped out for now... Never even thought about getting a new key Mick.... lol.... idiot... :\ :\ Re: Key help - Jules-C - 07-09-14 These guys can cut spare keys from the original key number or if you not got the number they can make a copy from a photo http://keysinthepost.com Re: Key help - MC680x0 - 08-09-14 (07-09-14, 10:42 PM)Jules-C link Wrote: These guys can cut spare keys from the original key number or if you not got the number they can make a copy from a photo http://keysinthepost.comthis is by far the better of the two key cuts: copy of the key you already have or cut of the registered key number. If your source key is knackered - especially if its a cut of a cut of the original! - then knackered will be your new key ! bit obvious really.  |
