Mikuni carb query - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Mikuni carb query (/showthread.php?tid=70170) |
Mikuni carb query - MC680x0 - 02-09-14 As I understand the carbs are type BSR33/4
Re: Mikuni carb query - darrsi - 03-09-14 4 carbs = 4 kits, perhaps? Just buy new carbs, they're a bargain. 8) https://www.yamahamotorcyclespares.co.uk/genuineparts/9657/11/yamaha%20fzs%20600%20fazer%2000-03/carburetor?uID=0 Re: Mikuni carb query - MC680x0 - 04-09-14 I wouldnt call that a bargain mate. I've decided to pull out the gunsons colortune and adjust the pilotscrews and do a resync; done two carbs today but then had to go and do another job. both carbs were way out and running well rich. sorted now. next steps is to tune the other two carbs then do a carb sync; should fix my erratic tacho needle ! Re: Mikuni carb query - singhangad - 29-06-18 I saw you got the color tune, do you recall how many turns from lock was the air fuel mixture screw turned out? plan to do the same so want to have a rough idea before i step into the unknown. Re: Mikuni carb query - YamFazFan - 30-06-18 (04-09-14, 09:18 PM)tweetytek link Wrote: I wouldnt call that a bargain mate. I suspect darrsi meant that ironically
Re: Mikuni carb query - His Dudeness - 30-06-18 (29-06-18, 04:29 PM)singhangad link Wrote: I saw you got the color tune, do you recall how many turns from lock was the air fuel mixture screw turned out? plan to do the same so want to have a rough idea before i step into the unknown.2 and 1/2 turns out is. The factory workshop manuals are in the download section |
