 what to look out for on a 4 yr garaged fzs - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: what to look out for on a 4 yr garaged fzs (/showthread.php?tid=70157) Pages:
what to look out for on a 4 yr garaged fzs - MC680x0 - 01-09-14 going to my pal's tomorrow to look at his fazer 600 which belonged to his deceased Dad. My pal now wants to sell the bike but it wont start. I've tested the battery and its dead so ordered a new battery. What can I expect in terms of starting/turnover problems?? All I know is that it has been garaged and not fired up for 4 years and has about 1 litre of petrol in the tank by the sounds of it - I'm told the petrol has been in there for the same amount of time. ?? Re: what to look out for on a 4 yr garaged fzs - bandit - 02-09-14 Sython old fuel out of tank put some fresh in,it will run rough to start with as old fuel in carbs but once the new gets through it should improve,if you purchase the bike I would recomend some of this added to a small amount of fuel to clean inside of carbs,it may save the hassle of stripping them down.It's not just for lawnmowers I've been using it for years with no problems (don't use Redex).   http://www.ebay.co.uk/itm/BRIGGS-STRATTON-PETROL-STABILIZER-FUEL-FIT-ADDITIVE-with-measuring-cap-/181510491282?pt=UK_Lawnmower_Parts_Accessories&hash=item2a42de4c92 Re: what to look out for on a 4 yr garaged fzs - wth - 02-09-14 http://foc-u.co.uk/index.php/topic,14484.0.html Re: what to look out for on a 4 yr garaged fzs - richfzs - 02-09-14 (02-09-14, 12:00 AM)bandit link Wrote:(don't use Redex). Why not? It's what I've used, successfully, to cure lumpy idling / refusing to idle, when the bike has been stood too long... Re: what to look out for on a 4 yr garaged fzs - darrsi - 02-09-14 STP Complete Fuel System Cleaner, half a bottle per full tank of fuel. Re: what to look out for on a 4 yr garaged fzs - Fazafou - 02-09-14 The cost of these fuel 'treatments' is crazy. You're better off replacing with fresh fuel as it will work out cheaper. Fill it with super unleaded and you'll be fine. The reason super is more expensive is the higher octane rating and additional additives to protect the fuel, rendering this stuff pointless. Redex is fine as an additive, but is just a thin oil for lubrication of the engine head. Re: what to look out for on a 4 yr garaged fzs - richfzs - 02-09-14 It's not about treating the fuel, it's about cleaning the carbs, and in particular the idle jets. There's bog all wrong with the fuel, the bike runs perfectly fine with the original fuel, once that bit of cleaning has been done. Re: what to look out for on a 4 yr garaged fzs - Fazafou - 02-09-14 (02-09-14, 09:58 AM)richfzs link Wrote:It's not about treating the fuel, it's about cleaning the carbs, and in particular the idle jets. There's bog all wrong with the fuel, the bike runs perfectly fine with the original fuel, once that bit of cleaning has been done.Good to know, very pleased for you, anyway I'm referring to the OPs bike and fuel. Re: what to look out for on a 4 yr garaged fzs - richfzs - 02-09-14 Yeah, so was I. What's your point? Re: what to look out for on a 4 yr garaged fzs - Fazafou - 02-09-14 You said the bike runs fine and the fuel is fine, the OP hasn't even started it and the fuels 4 years old. Not quite related is it. Re: what to look out for on a 4 yr garaged fzs - His Dudeness - 02-09-14 It'll probably start with the new battery. Might not run 100% but it should start. I'd check the tank for rust and check the oil before trying to start it. The brake fluid will have to be changed too and the tyres are probably old and will need to be replaced. If you're keeping it I'd take the carbs off and clean them and change the plugs, oil and filter, air filter, then grease everything that needs grease, give the calipers a clean. Basically give it a good service. Re: what to look out for on a 4 yr garaged fzs - richfzs - 02-09-14 (02-09-14, 12:16 PM)Fazafou link Wrote: You said the bike runs fine and the fuel is fine, the OP hasn't even started it and the fuels 4 years old. Go back and read the whole post. I said, "it runs fine once that bit of cleaning is done" . Prior to that, lumpy idling is often present, symptomatic of fuel evaporating and leaving junk in the carbs. The redex (or other cleaners as suggested) helps clean that crap out, and it runs sweet again. New fuel won't do that cleaning. So yes, it's very related to the op questioning what he should do. Re: what to look out for on a 4 yr garaged fzs - Fazafou - 02-09-14 Redex is simply an upper head lubricant. Won't do any harm, but why not just replace the fuel completely. That 4 year old stuff will be low in octane now and no amount of redex will fix that. Re: what to look out for on a 4 yr garaged fzs - MC680x0 - 02-09-14 Cheers fellas. I did have to put redex into my own carb fazer to help out with idling, one the white smoke stopped coming out, it's sweet as a nut. High octane unleaded had no effect ! Re: what to look out for on a 4 yr garaged fzs - richfzs - 02-09-14 You must be looking at a different redex to me. It's a fuel system cleaner! New fuel won't help clean the residue from the evaporated fuel that is in the carbs. Re: what to look out for on a 4 yr garaged fzs - Fazafou - 02-09-14 It's touted as a cleaner but check the contents, it's just based on light oils. I use it myself in a classic motor for upper lubrication, good stuff so I'm not knocking it, just not needed in modern engibes IMO. Re: what to look out for on a 4 yr garaged fzs - richfzs - 02-09-14 Well it works, as I've described above. I wouldn't use it if the bike was used regularly, and indeed I only put it in if the idling is an issue - which is only if the bike has stood for at least 6 months. Half a bottle, for a full tank of fuel, and 15-20 mins of riding, idling issue gone. And I've never had to throw fuel away, or buy the high octane stuff It does what it says on the bottle, regardless of whether it's light oils (which isn't really a surprise) or magic juice. Re: what to look out for on a 4 yr garaged fzs - richfzs - 02-09-14 To respond to someone else's post, yeah maybe it is expensive (although 5.49 a bottle on hakfrauds isn't the end of the world, to get 2 treatments) - but how much is your time worth, stripping carbs down to clean them (or even just siphoning off fuel to throw it away), when you don't necessarily need to? Sounds cheap to me. Re: what to look out for on a 4 yr garaged fzs - MC680x0 - 02-09-14 (02-09-14, 12:19 PM)His Dudeness link Wrote: It'll probably start with the new battery. Might not run 100% but it should start. I'd check the tank for rust and check the oil before trying to start it. The brake fluid will have to be changed too and the tyres are probably old and will need to be replaced. If you're keeping it I'd take the carbs off and clean them and change the plugs, oil and filter, air filter, then grease everything that needs grease, give the calipers a clean. Basically give it a good service.cheers mate; I plan to sell it. how do I check for tank rust - I'm shining a torch in and can see any but this does not necessarily mean it isnt rusty ?? new plugs, filters and oil at the ready. dont want to get into dismantling the carbs if I can avoid it so will drop redex in first and see what happens. brakes seem to work ok but will change and bleed as the fluid has been in there some years - good tip - thanks Cheers Re: what to look out for on a 4 yr garaged fzs - His Dudeness - 03-09-14 (02-09-14, 09:10 PM)MC680x0 link Wrote: [quote author=His Dudeness link=topic=14557.msg164657#msg164657 date=1409656782]cheers mate; I plan to sell it. how do I check for tank rust - I'm shining a torch in and can see any but this does not necessarily mean it isnt rusty ?? new plugs, filters and oil at the ready. dont want to get into dismantling the carbs if I can avoid it so will drop redex in first and see what happens. brakes seem to work ok but will change and bleed as the fluid has been in there some years - good tip - thanks Cheers [/quote] You could check the fuel filter on it to see if it's gone a rusty colour. Take the tank off and slosh some new petrol around it and drain it out. Check if it's rusty. If it's not you should be fine. A new fuel filter wouldn't be a bad idea, they're only a few quid. If don't want to take the carbs off the fuel cleaner should do a good enough job. If you are taking them off there's a workshop manual in the download section. Brake fluid absorbs water over time so it'll have to be changed and the calipers will definitely need to be cleaned or they'll start sticking. The rear one especially. Have a look at the date stamp on the tyres but they're probably due a change now.  |
