Back Tyre - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Back Tyre (/showthread.php?tid=70155) |
Back Tyre - red imp - 01-09-14 I have just noticed that the previous owner has had the back tyre plugged after i assume was a puncture. is it safe to ride or would it be best to replace the tyre? I have done a few miles on it since i bought the bike. Re: Back Tyre - slimwilly - 01-09-14 Mine was plugged at a month old, a few thousand miles now, tyre worn out , no problems Re: Back Tyre - stevierst - 01-09-14 I've never replaced a tyre that could be plugged, always had it repaired, or if it's getting on a bit, repaired it myself. Had dozens of flats over the years, never had a plug fail. Re: Back Tyre - dazza - 01-09-14 I wouldn't sweat it either mate. I've had a couple of plugs in one rear tyre before and that's on a gen 1. If I had the slower gen 2, then it really wouldn't concern me at all.
Re: Back Tyre - red imp - 01-09-14 Thank for the advice. Upwards on onwards it is then.
Re: Back Tyre - Tmation - 02-09-14 There is a manufacturers recommended speed limit on push through plugs of about 40 or 50 mph, also they are designed as a get you home solution. If you have the tyre removed and a vulcanised patch/plug fitted it would be safer. Saying that I drove halfway across Saudi Arabia in my Volvo 850 T5, mostly around the 140 mph mark, and only found out later that the dealer had fitted a plug when it was in for service :eek [size=78%] [/size] Re: Back Tyre - sadlonelygit - 02-09-14 did a track day with a plugged rear, no problems. Re: Back Tyre - fireblake - 02-09-14 I rode a FireBlade down our local race track at an indicated 165mph with a plugged back tyre with no problems, it was as good as normal. Mickey Re: Back Tyre - onejay - 17-09-14 My rear tyre had 10 miles on it I had it plugged, no problems at all. |
