jets - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bits and bobs (https://foc-u.co.uk/mybb/forumdisplay.php?fid=67) +--- Forum: Articles (https://foc-u.co.uk/mybb/forumdisplay.php?fid=85) +---- Forum: FZS600 (https://foc-u.co.uk/mybb/forumdisplay.php?fid=86) +---- Thread: jets (/showthread.php?tid=70036) |
jets - wutangbuzz - 20-08-14 I've stuck a race can on my fazer which makes it sound much more fun but its made a big flat spot early in the revs. Anyone know what jets I can use to get rid of this? Re: jets - pilgo - 01-09-14 stick a K&N air filter in and see if that helps,been told that you dont need to re jet just for a freer breathing can,others on here might know otherwise? maybe get your carbs balanced,improved the feel of the engine when i had mine done.and cured the rattle i had from the clutch Re: jets - stevierst - 01-09-14 They're normally ok to fit an end can on, there may be something else wrong there! I'd make a start with a Carb balance and see if that helps. Re: jets - BBROWN1664 - 20-10-14 Do the carb balancing and tps adjustment. Makes a big difference. If you still think it's suffering, put a k&n filter in. No new jets are required. The fzs was over fuelled from the factory. |
