Remove / Refit pipes - parts needed? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Remove / Refit pipes - parts needed? (/showthread.php?tid=69839) |
Remove / Refit pipes - parts needed? - keratos - 03-08-14 found this.. http://foc-u.co.uk/index.php/topic,90.0.html 1.Any seals/sealant/gaskets etc. needed when I remove and refit the downpipes headers and foot (into can) 2.Is this applicable to FZS600 "2000" model 3.Where are the pics from the above thread? TIA Re: Remove / Refit pipes - parts needed? - His Dudeness - 04-08-14 My advice is leave them unless they really have to be taken off. If you snap a stud you'll be in trouble Re: Remove / Refit pipes - parts needed? - Panthor - 04-08-14 1. Didnt use ay sealant when doing mine, didnt need it. I Changed the circular copper gaskets at the head and just reused the one on the foot into can. 2. Applies to all FZS600 (mines a 2003) 3. not sure where pics are but its all pretty easy to do when you take a look at your bike. didnt snap any studs on mine, did the soaking with WD40 once a day every day for 2 weeks before had though. (just be careful) Re: Remove / Refit pipes - parts needed? - keratos - 04-08-14 cheers Panthor. Re: Remove / Refit pipes - parts needed? - Jules-C - 04-08-14 I'd get a spare gasket for the header to end can join. The join doesn't always come apart cleanly. If you don't need it keep it till next time Re: Remove / Refit pipes - parts needed? - keratos - 04-08-14 confused :2guns so is the advice to change both head and foot gaskets , or not , or "suck it and see". The default to assume the worst case is usually safest best so assuming this I need copper head gaskets and the footer (to can) join ? Re: Remove / Refit pipes - parts needed? - noggythenog - 04-08-14 (04-08-14, 02:06 PM)keratos link Wrote:confused :2guns so is the advice to change both head and foot gaskets , or not , or "suck it and see". The default to assume the worst case is usually safest best so assuming this I need copper head gaskets and the footer (to can) join ? I think it depends on what end can and header combination you have.......when i took off my original end can i totally destroyed the gasket and my Simmi performance can fitted over it nice and tight and then the clamp tightened it up so much that i didn't need a gasket, same app,ied when i got stainless headers........but ive heard of others moaning about the seal on other cans not being good enough. Re: Remove / Refit pipes - parts needed? - spyder - 05-08-14 Used new copper seals for headers- only £6 from Motad, everything undid without prob. I think the end can could seal better but the MOT guy was happy with it Re: Remove / Refit pipes - parts needed? - keratos - 05-08-14 Jeez.. What am I worrying about.. At these prices I should just replace anyway. Cheers! |
