Vibration noise around the clocks area. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Vibration noise around the clocks area. (/showthread.php?tid=69808) |
Vibration noise around the clocks area. - solorider - 01-08-14 I have a vibration around the clocks at around 3k revs, this has been there ever since I have owned the bike, if I push onto the clocks the noise goes but tube clocks are tight with no exesive movement, and the bike is so smooth with virtually no noticeable vibration through the legs,seat, handlebars or tank. Is there anything that is common to cause this vibration noise? Re: Vibration noise around the clocks area. - mickvp - 01-08-14 I've had two vibrations from my clock area before. The first one was an aftermarket screen which was touching the fairing Infills when it vibrated at a certain rpm. The second one was worn out padding on the underside of the infill which causes the. To vibrate. A couple of sticky foam pads from eBay later and no vibrations or buzzing noises. Worth a look for you anyway, try pressing down the Infills when it does it see if that's your cause
Re: Vibration noise around the clocks area. - solorider - 04-08-14 If I press in the top of the clocks the vibration noise goes. Re: Vibration noise around the clocks area. - b1k3rdude - 04-08-14 There are a few things that cause vibs in the general location -
(04-08-14, 02:49 PM)solorider link Wrote:If I press in the top of the clocks the vibration noise goes.That will be the top end of the sub-loom, locate where is rattling agaisnt the headlight/fairing and apply some foam tape. |
