headlight bowl, can i remove? adjustment issues aswell. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: headlight bowl, can i remove? adjustment issues aswell. (/showthread.php?tid=69706) |
headlight bowl, can i remove? adjustment issues aswell. - Paulfzs - 22-07-14 After playing around with my headlight ive ordered a h1 osram bulb but the standard h1 thats in it is terrible! i have a light the size of a large dinner plate on the road infront of me, i was wondering if its a massive mot failure or if most people would just look past it and not care too much. i will likely do the headlight mod for both bulbs too. another issue i have is adjusting it. the up + down does absolutely nothing, only way i can move it up and down is with the left + right adjusters but they move diagonally so they go up and right or down and left. any ideas? edit: Pushed the cover off, just 2 little legs with a bit on the ends bent over to hold it in.. casn easily be put back in, didn't need to remove headlight just pushed in then taken out of the other bulb hole...
