No ign/oil light till i press starter - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: No ign/oil light till i press starter (/showthread.php?tid=69646) |
No ign/oil light till i press starter - easym5 - 17-07-14 Hi after having some work on the head i rebuilt everything turned the key and no lights on dash,but when i push starter lights come on and ignition cut out relay clicks,have double checked wiring but everything seems good so could it be the relay unit itself ? Re: No ign/oil light till i press starter - thunderpantz - 17-07-14 Is your fuel pump working? Re: No ign/oil light till i press starter - easym5 - 17-07-14 Yes it is everything is lights etc Re: No ign/oil light till i press starter - His Dudeness - 18-07-14 Might be a flat battery or a bad connection to the battery. Re: No ign/oil light till i press starter - easym5 - 18-07-14 Obviously no one has had this problem before but if you do answer is the main relay in side panel Re: No ign/oil light till i press starter - darrsi - 18-07-14 (18-07-14, 10:58 AM)easym5 link Wrote: Obviously no one has had this problem before but if you do answer is the main relay in side panel http://www.yamahamotorcyclespares.co.uk/genuineparts/9657/45/yamaha%20fzs%20600%20fazer%2000-03/electrical%201?uID=0 This is a good site for bits and bobs, or just to check things out, although the prices can be a bit steep. |
