carb balance - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: carb balance (/showthread.php?tid=69507) |
carb balance - kelly1 - 04-07-14 hi tried to balance carbs with a morgan carbtune carbs 1and2 ok carb4 ok carb3 goes to the top of the tube and will not balance suggestions please Re: carb balance - darrsi - 04-07-14 You should be balancing 1 with 2 together first. Then balance 3 with 4 on their own separately. Then with the middle screw adjust until 1&2 are level with 3&4. Re: carb balance - Punkstig - 05-07-14 Have you checked there's no problems with the connection on No. 3? Does that tube have the 2 little tubes inside to throttle the compression? Have you swapped the tube onto another cylinder to confirm it's not the tube/ gauge at fault? Re: carb balance - Jamieg285 - 07-07-14 (04-07-14, 04:50 PM)darrsi link Wrote: You should be balancing 1 with 2 together first. Then go back and re-do 1&2 as they will have changed, then 3&4, then 1&2 again, then the left pair to right pair again. Repeat for about an hour until it finally all lines up.
Re: carb balance - keratos - 07-07-14 (07-07-14, 12:50 PM)Jamieg285 link Wrote: [quote author=darrsi link=topic=13904.msg157221#msg157221 date=1404489050] Then go back and re-do 1&2 as they will have changed, then 3&4, then 1&2 again, then the left pair to right pair again. Repeat for about an hour until it finally all lines up. [/quote] Liked this post, I'm trying to get down to an hour but never manage :rollin Re: carb balance - HarryHornby - 08-07-14 Took me about an hour last time too, I now need to find a field to do mine in though, because my new exhaust and living in a very respectable close doesn't make for keeping the neighbours happy when doing my carbs LOL |
